Home » Language IDEs » PHP Development Tools (PDT) » Displaying classes
Displaying classes [message #61950] Mon, 03 December 2007 03:19 Go to next message
Originally posted by: news_post.jimmo.com
I installed pdt-all-in-one-1.0-R20070917 and loaded a PHP containing all of
my classes. In the left column of the IDE is there is a tab "PHP Project
Outline". It contains the entries Constants, Classes, Functions. Clicking
on them does nothing. I googled some references to the IDE and the way I
understand it is that these should show you the Constants, Classes, and
Functions in the current file. If not, what is the purpose of this? If so,
what do I need to do to active this functionality? Thanks for any help.
Jim Mohr
Re: Displaying classes [message #61977 is a reply to message #61950] Mon, 03 December 2007 04:02 Go to previous messageGo to next message
James Mohr wrote:
> Hello,
> of my classes. In the left column of the IDE is there is a tab "PHP
> Project Outline". It contains the entries Constants, Classes, Functions.
> Clicking on them does nothing. I googled some references to the IDE and
> the way I understand it is that these should show you the Constants,
> Classes, and Functions in the current file. If not, what is the purpose of
> this? If so, what do I need to do to active this functionality? Thanks for
> any help.
If I copy the file in question to a different location and open it with
File->Open File, then I can navigate the classes. However. if I open the
file from the list of files in project the three entries are dead.
Re: Displaying classes [message #62044 is a reply to message #61950] Wed, 05 December 2007 07:50 Go to previous messageGo to next message
Originally posted by: dserodio.gmail.com
James Mohr wrote:
> Hello,
What do you mean by "loaded a PHP"? Did you create a PHP Project? Are
your files contained in this project?
Daniel Serodio
Re: Displaying classes [message #62114 is a reply to message #62044] Wed, 05 December 2007 15:46 Go to previous messageGo to next message
Daniel Serodio wrote:
> James Mohr wrote:
>> Hello,
>> of this? If so, what do I need to do to active this functionality? Thanks
>> for any help.
Oops. I loaded a PHP file containing all of my classes.
Re: Displaying classes [message #62162 is a reply to message #62114] Wed, 05 December 2007 18:45 Go to previous message
As was stated earlier. Make sure you have your classes in a PHP Project.
You can create a PHP Project by going to File->New->Project, select
the PHP Category, and select the PHP Project. Follow the wizard from
there.
Once the Project is created, make sure you copy all your PHP related
files including the appropriate directory structures into the new PHP
Project. You should also be using the PHP Explorer view and PHP
Perspective when working with the files. But the most important thing
is making sure you have the files in a PHP Project, otherwise some of
the functionality won't be available.
Dave
Previous Topic:Re: Disabling "Building workspace"
Next Topic:PHP script extension not found
Current Time: Tue Jul 22 15:32:18 EDT 2025
Powered by FUDForum. Page generated in 0.03995 seconds
