Home » Eclipse Projects » Plugin Development Environment (PDE) » P2 generator - How to specify feature categories ?
P2 generator - How to specify feature categories ? [message #61913] Fri, 15 May 2009 07:48 Go to next message
GianMaria Romanato is currently offline GianMaria RomanatoFriend
Member
I am using PDE Build to build a set of top level features representing
different software products: each product is represented by one of the top
level feature and most of the top level features include some other shared
feature.
All the build process works fine (I modified the allEmment.xml to list all
my top level features in the allElementDelegator target).
After building I am running p2generator to produce the repository for the
built features. I cannot understand how to categorize features. I would
like to have in the repository a separate root for every top level feature
which includes also the nested shared features but at the moment I am
getting a single "Uncategorized" root node where all features are listed.
In other words, given two top level features F1 and F2 which share feature
G,
I would like to have a P2 repository that looks like the following:
- F1 category
- F1
- G
and
- F2 category
- F2
- G
but I am getting
- Uncategorized
- F1
- F2
- G
Thanks in advance for your help.
GianMaria Romanato
Developing for Virgo using PDE: http://bit.ly/1w0tTit
Global JNDI in Virgo: http://bit.ly/1to42mn
Hyperic to monitor Virgo: http://bit.ly/W1Fst9
Profile Virgo with JProfiler http://bit.ly/1FBLGCw
Re: P2 generator - How to specify feature categories ? [message #62054 is a reply to message #61913] Sat, 16 May 2009 21:54 Go to previous messageGo to next message
Ben Vitale is currently offline Ben VitaleFriend
I'm not sure the best way to achieve that in 3.4.x.
There was work completed in 3.5M7 to author category definitions. Its
mentioned in the PDE section of New and Noteworthy for that milestone:
http://tinyurl.com/pyspeb
See also the following bug for where definitions can be used:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=272362
There may be a better doc out there (or coming soon) but I don't have a
pointer to it.
Cheers
Ben
GianMaria Romanato wrote:
> Hello,
> top level feature and most of the top level features include some other
> shared feature.
> all my top level features in the allElementDelegator target).
> the built features. I cannot understand how to categorize features. I
> would like to have in the repository a separate root for every top level
> feature which includes also the nested shared features but at the moment
> I am getting a single "Uncategorized" root node where all features are
> listed.
> feature G,
> - F1 category
> - F1
> - G
> and
> - F2 category
> - F2
> - G
> but I am getting
> - Uncategorized
> - F1
> - F2
> - G
> GianMaria Romanato
Re: P2 generator - How to specify feature categories ? [message #62724 is a reply to message #62054] Fri, 22 May 2009 19:37 Go to previous message
Andrew Niefer is currently offline Andrew NieferFriend
You can create a site.xml (or in 3.5 a category.xml) using the UI. You
can define your categories there like you would for an old update site.
The 3.4.x EclipseGeneratorApplication supports a -site option that will
take a site.xml file.
In 3.5, the p2.generator and task supports a "site" attribute.
Also in 3.5, you can do
<eclipse.publish.featuresAndBundles
site="file:/path/site.xml"
repository="file:/path/repo" />
or
category="file:/path/category.xml"
to add categories to a repository.
-Andrew
> pointer to it.
> Cheers
> Ben
>> Hello,
>> other shared feature.
>> level feature which includes also the nested shared features but at
>> the moment I am getting a single "Uncategorized" root node where all
>> feature G,
>> - F1 category
>> - F1
>> - G
>> and
>> - F2 category
>> - F2
>> - G
>> but I am getting
>> - Uncategorized
>> - F1
>> - F2
>> - G
>> GianMaria Romanato
Re: P2 generator - How to specify feature categories ? [message #597579 is a reply to message #61913] Sat, 16 May 2009 21:54 Go to previous message
pointer to it.
Cheers
Ben
> Hello,
> shared feature.
> listed.
> feature G,
> - F1 category
> - F1
> - G
> and
> - F2 category
> - F2
> - G
> but I am getting
> - Uncategorized
> - F1
> - F2
> - G
> GianMaria Romanato
Re: P2 generator - How to specify feature categories ? [message #597782 is a reply to message #62054] Fri, 22 May 2009 19:37 Go to previous message
or
-Andrew
> pointer to it.
> Cheers
> Ben
>> Hello,
>> feature G,
>> - F1 category
>> - F1
>> - G
>> and
>> - F2 category
>> - F2
>> - G
>> but I am getting
>> - Uncategorized
>> - F1
>> - F2
>> - G
>> GianMaria Romanato
Previous Topic:PDE Build, SVN and jar qualifiers
Next Topic:--launcher.ini doesn't work in Run Configuration
Current Time: Mon Jun 14 19:30:55 GMT 2021
Powered by FUDForum. Page generated in 0.02244 seconds
