Teneo latest build: backward compatibility, new cvs location [message #609656] |
Thu, 06 September 2007 20:19 |
Martin Taal Messages: 5468 Registered: July 2009 |
The latest Teneo build has some smaller changes which can break backward-compatibility in some
special cases (hibernate):
- unsaved-value: if the id-efeature has a default value then this default value is set as the
unsaved-value of the id property in the hbm mapping.
- featuremap-mapping: to prevent nameclashes the columns created for a feature map mapping are
prefixed with the feature map efeature name
Teneo has moved to a new cvs location:
host: dev.eclipse.org
repository: /cvsroot/modeling
module: org.eclipse.emf/org.eclipse.emf.teneo
See the release notes for other changes.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.01325 seconds
