Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO] Can't migrate ecore file in Eclipse 3.3
[CDO] Can't migrate ecore file in Eclipse 3.3 [message #608916] Wed, 25 July 2007 20:06
Mark Geib is currently offline Mark GeibFriend
I have recently installed Eclipse 3.3, and all the associated plugins for
EMF, etc.
I then installed the most recently released CDO plugins, created a simple
ecore file and then tried to migrate the ecore file.
When I make the selection I get a popup that states that the CDO client
plugin is not in the workspace, shoudl it import...as source plugin.
I select OK and then get an error that follows. Is this possibly an issue
with Eclipse 3.3 and CDO or something else.?
Mark.
java.lang.NoSuchMethodError:
org.eclipse.pde.internal.ui.wizards.imports.PluginImportWiza rd.getImportOperation(Lorg/eclipse/swt/widgets/Shell;I[Lorg/ eclipse/pde/core/plugin/IPluginModelBase;Z)Lorg/eclipse/jfac e/operation/IRunnableWithProgress;
org.eclipse.emf.cdo.utilities.migrator.MigratorUtil.importCl ientPlugin(MigratorUtil.java:358)
org.eclipse.emf.cdo.utilities.migrator.internal.actions.Abst ractFileAction.ensureClientProject(AbstractFileAction.java:1 42)
org.eclipse.emf.cdo.utilities.migrator.internal.actions.Abst ractFileAction.run(AbstractFileAction.java:87)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:256)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Previous Topic:[Teneo] can't deserialize EObjects which contain Teneo proxies
Next Topic:[Teneo] Not-null property references a null value
Current Time: Fri Aug 12 13:06:11 GMT 2022
Powered by FUDForum. Page generated in 0.02293 seconds
