"does not translate to an instance class" [message #608612] |
Thu, 28 June 2007 21:03 |
Julia Messages: 85 Registered: July 2009 |
Member |
Hi Martin,
I'm still trying to debug my NPE when I create the schema. I have trying
to find a simple example that will give me NPE on Schema creation by
shorten/simplifying my original xsds. All the xsds that failed so far had
used ecore:references. If I removed the ecore annotation from one xsd
file. The schema would build. However, it did not work in all cases. This
one simplified version gave me this error:
1813 [main] ERROR org.eclipse.emf.teneo.jpox.mapper.JPOXMappingException
- Uri: ComponentDefinition does not translate to an instance class
org.eclipse.emf.teneo.jpox.mapper.JPOXMappingException: Uri:
org.eclipse.emf.teneo.jpox.mapper.MappingUtil.getImplNameOfE Class(MappingUtil.java:60)
org.eclipse.emf.teneo.jpox.mapper.association.ManyToOneMappe r.map(ManyToOneMapper.java:100)
org.eclipse.emf.teneo.jpox.mapper.property.EClassFeatureMapp er.processPersistableMember(EClassFeatureMapper.java:153)
org.eclipse.emf.teneo.jpox.mapper.property.EClassFeatureMapp er.map(EClassFeatureMapper.java:90)
org.eclipse.emf.teneo.jpox.mapper.JPOXMappingGenerator.proce ssClassAnnotation(JPOXMappingGenerator.java:250)
org.eclipse.emf.teneo.jpox.mapper.JPOXMappingGenerator.gener ate(JPOXMappingGenerator.java:133)
org.eclipse.emf.teneo.jpox.mapper.GenerateJDO.createORMapper File(GenerateJDO.java:104)
at org.eclipse.emf.teneo.jpox.mapper.GenerateJDO.main(GenerateJ DO.java:82)
What does this mean?
FUDForum. Page generated in 0.02163 seconds
