Class cast exception on customizer OK click [message #607764] |
Sat, 14 May 2005 20:33 |
Suddenly getting the error below any time I click VE's OK button on my
customizer. My code seems to complete entirely. The property sheet
gets updated with the correct values. No code is generated, though.
Any idea the cause? Suggestions on how to debug/determine what class is
causing the problem? What is the minimum necessary VE part of CVS that
I should check out to support debugging this?
!ENTRY org.eclipse.ve.java.core 2 0 2005-05-14 17:24:14.231
!MESSAGE Exception thrown.
!STACK 0
java.lang.ClassCastException:
org.eclipse.ve.internal.java.core.TypeReferenceCellEditor
org.eclipse.ve.internal.java.core.CustomizeJavaBeanAction.cu stomizerOK
(CustomizeJavaBeanAction.java:234)
at org.eclipse.ve.internal.java.core.CustomizeJavaBeanAction.ru n
(CustomizeJavaBeanAction.java:137)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection
(ActionContributionItem.java:538)
at org.eclipse.jface.action.ActionContributionItem.access$2
(ActionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t
(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.EventTable.sendEvent
(EventTable.java:82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents
(Display.java:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch
(Display.java:2527)
at org.eclipse.ui.internal.Workbench.runEventLoop
(Workbench.java:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
(Workbench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench
(PlatformUI.java:143)
at org.eclipse.ui.internal.ide.IDEApplication.run
(IDEApplication.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run
(PlatformActivator.java:228)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run
(EclipseStarter.java:344)
(EclipseStarter.java:156)
at sun.reflect.NativeMethodAccessorImpl.invoke
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
FUDForum. Page generated in 2.07685 seconds
