IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #607359] |
Sun, 08 May 2005 00:55 |
Installed VE with the correct dependencies for 3.1M6. When I use the
Visual Class wizard, I get a frame which looks correct.
However, if I click on the content pane, the properties view shows a
"debugGraphicsOptions" property with the value "IWAV0104E ERROR - Value
not one of the enumerated values"
Visual composition does not work: dropping a button on the content pane
looks correct and a getJButton() method is created, but VE does not
generate the expected linking code (jContentPane.add(getJButton() ... ))
in getContentPane() method.
Cleaning the workspace does not help. Switching to a completely new and
empty workspace *does* enable VE to work as expected. I have too much
good stuff in my current workspace to manually transfer the projects.
Any clues as to the problem and a (practical) way to fix up my existing
workspace?
!SESSION 2005-05-07 21:24:33.157
eclipse.buildId=I20050401-1645
java.version=1.5.0
Command-line arguments: -os win32 -ws win32 -arch x86 -clean -data D:
\DevFiles\EclipseWorkSpace31M6
!ENTRY org.eclipse.jem.proxy 2 0 2005-05-07 21:24:33.157
!MESSAGE java.lang.RuntimeException
at org.eclipse.jem.internal.proxy.initParser.Static.evaluate
(Static.java:123)
org.eclipse.jem.internal.proxy.initParser.InitializationStri ngParser.eva
luate(InitializationStringParser.java:157)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un
(ConnectionHandler.java:236)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n
(ConnectionThread.java:47)
!ENTRY org.eclipse.ve.java.core 2 0 2005-05-07 21:24:33.167
!MESSAGE
+++ Warning +++: Sat May 07 21:24:33 PDT 2005 Unable to create
enumeration value for DebugGraphics.NONE_OPTION
!MESSAGE Exception thrown.
!STACK 0
java.lang.InstantiationException: IWAV0125E "DebugGraphics.NONE_OPTION"
is too complicated to be evaluated
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.create
BeanProxy(REMStandardBeanProxyFactory.java:262)
org.eclipse.jem.internal.proxy.remote.REMAbstractBeanTypePro xy.newInstan
ce(REMAbstractBeanTypeProxy.java:536)
org.eclipse.jem.internal.proxy.remote.REMIntegerTypeBeanType Proxy.newIns
tance(REMIntegerTypeBeanTypeProxy.java:103)
org.eclipse.ve.internal.java.core.EnumeratedLabelProvider.ge tEnumeratedV
alues(EnumeratedLabelProvider.java:51)
org.eclipse.ve.internal.java.core.EnumeratedLabelProvider.ge tText
(EnumeratedLabelProvider.java:90)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.getValu
eAsString(AbstractPropertySheetEntry.java:722)
at org.eclipse.ui.views.properties.PropertySheetViewer.updateEn try
(PropertySheetViewer.java:1220)
at org.eclipse.ui.views.properties.PropertySheetViewer.createIt em
(PropertySheetViewer.java:359)
org.eclipse.ui.views.properties.PropertySheetViewer.updateCh ildrenOf
(PropertySheetViewer.java:1177)
at org.eclipse.ui.views.properties.PropertySheetViewer.access$2
(PropertySheetViewer.java:1101)
$3.childEntriesChanged(PropertySheetViewer.java:308)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.fireChi
ldEntriesChanged(AbstractPropertySheetEntry.java:373)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refresh
ChildEntries(AbstractPropertySheetEntry.java:831)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValu
es(AbstractPropertySheetEntry.java:1013)
at org.eclipse.ui.views.properties.PropertySheetViewer.setInput
(PropertySheetViewer.java:875)
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged
(PropertySheetPage.java:392)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelec
tionChanged(EToolsPropertySheetPage.java:230)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2
(EToolsPropertySheetPage.java:223)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e
$1.run(EToolsPropertySheetPage.java:216)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages
(Synchronizer.java:118)
at org.eclipse.swt.widgets.Display.runAsyncMessages
(Display.java:2871)
at org.eclipse.swt.widgets.Display.readAndDispatch
(Display.java:2530)
at org.eclipse.ui.internal.Workbench.runEventLoop
(Workbench.java:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
(Workbench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench
(PlatformUI.java:143)
at org.eclipse.ui.internal.ide.IDEApplication.run
(IDEApplication.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run
(PlatformActivator.java:228)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run
(EclipseStarter.java:344)
(EclipseStarter.java:156)
at sun.reflect.NativeMethodAccessorImpl.invoke
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
FUDForum. Page generated in 0.05933 seconds
