Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Can someone provide an example of using the @IdBag annotation in Elver...
Can someone provide an example of using the @IdBag annotation in Elver... [message #606783] Thu, 24 May 2007 20:35
Michael Kanaley is currently offline Michael KanaleyFriend
Member
What is the syntax of the annotation?
I have attached an ecore as an example that is working with the "refs"
EAttribute of SomeClass using bags. I would like it to use IdBags instead.
Also, as a side note, the real problem that I am trying to work around is
the following Hibernate exception when left joins on multiple bag attributes
are done.
"org.hibernate.HibernateException: cannot simultaneously fetch multiple
bags".
Will switching to idbags fix this issue?
-mike
  • Attachment: test.bag.zip
    (Size: 17.70KB, Downloaded 102 times)
Previous Topic:[Teneo] Resolving lists
Next Topic:[Teneo] Without eclipse
Current Time: Tue Jan 19 22:42:15 GMT 2021
Powered by FUDForum. Page generated in 0.02284 seconds
