Home » Eclipse Projects » Plugin Development Environment (PDE) » NPE in AbstractBundleContainer with Eclipse 3.6
NPE in AbstractBundleContainer with Eclipse 3.6 [message #605866] |
Thu, 27 May 2010 07:59 |
I'm trying to move an RCP application from 3.5 to 3.6
With 3.6, a NPE occured at startup:
!ENTRY org.eclipse.core.resources 4 2 2010-05-27 09:44:18.768
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 0
at org.eclipse.pde.internal.core.target.AbstractBundleContainer .getVMArguments(AbstractBundleContainer.java:525)
at org.eclipse.pde.internal.core.target.TargetPlatformService.n ewDefaultTargetDefinition(TargetPlatformService.java:525)
at org.eclipse.pde.internal.core.PluginModelManager.initDefault TargetPlatformDefinition(PluginModelManager.java:574)
at org.eclipse.pde.internal.core.PluginModelManager.initializeT able(PluginModelManager.java:527)
at org.eclipse.pde.internal.core.PluginModelManager.findModel(P luginModelManager.java:869)
at org.eclipse.pde.core.plugin.PluginRegistry.findModel(PluginR egistry.java:105)
at org.eclipse.pde.internal.core.builders.BundleErrorReporter.v alidateContent(BundleErrorReporter.java:50)
at org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.validateManifestFile(ManifestConsistencyChecker.java:2 69)
at org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.validateProject(ManifestConsistencyChecker.java:227)
at org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.build(ManifestConsistencyChecker.java:157)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:629)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:172)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:203)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:255)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:258)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:311)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:343)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:144)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:242)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
I set a breakpoint in 3.5 and so I notice that the method getVMArguments is not called.
Any idea why this happened?
Aurelien Pupier - BonitaSoft S.A.
"http://scratsh.wordpress.com/"
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Re: NPE in AbstractBundleContainer with Eclipse 3.6 [message #605871 is a reply to message #605866] |
Thu, 27 May 2010 15:01 |
Ouch I forgot to mention the version of Eclipse 3.6 :s so it is the RC1, build ID: 20100520-1308
The plugin where the NPE occured is: org.eclipse.pde.core_3.6.0.v20100512.jar
I notice that the same error is happening when I try to setRawClassPath on a java project.
Do you have any idea why the FrameworkAdmin service will not be available? What can I check?
Re: NPE in AbstractBundleContainer with Eclipse 3.6 [message #605873 is a reply to message #605866] |
Thu, 27 May 2010 15:12 |
I debug a little.
In serviceRegistry, l.887: there is nothing register for the class " org.eclipse.equinox.internal.provisional.frameworkadmin.Fram eworkAdmin " in the map "publishedServicesByClass"
This is the keyset of the map:
publishedServicesByClass.keySet();
(java.util.HashMap$KeySet) [org.eclipse.core.runtime.IBundleGroupProvider, org.eclipse.osgi.framework.console.ConsoleSession, org.eclipse.equinox.p2.core.IProvisioningAgent, org.eclipse.core.internal.preferences.exchange.IProductPrefe rencesService, org.eclipse.osgi.service.urlconversion.URLConverter, org.eclipse.core.runtime.IExtensionRegistry, javax.xml.parsers.DocumentBuilderFactory, org.eclipse.core.runtime.preferences.IPreferencesService, org.eclipse.osgi.service.runnable.StartupMonitor, org.eclipse.osgi.service.pluginconversion.PluginConverter, org.eclipse.core.internal.preferences.exchange.ILegacyPrefer ences, org.eclipse.osgi.service.runnable.ApplicationLauncher, org.eclipse.osgi.framework.log.FrameworkLog, org.eclipse.core.runtime.content.IContentTypeManager, org.eclipse.osgi.service.localization.BundleLocalization, javax.xml.parsers.SAXParserFactory, org.eclipse.core.runtime.IAdapterManager, org.eclipse.osgi.service.debug.DebugOptions, org.eclipse.equinox.p2.core.IAgentLocation, org.eclipse.osgi.service.resolver.PlatformAdmin, org.eclipse.pde.internal.core.target.provisional.ITargetPlat formService, org.eclipse.core.runtime.jobs.IJobManager, org.osgi.service.framework.CompositeBundleFactory, org.eclipse.equinox.internal.provisional.configurator.Config urator, org.eclipse.osgi.service.environment.EnvironmentInfo, org.eclipse.update.configurator.IPlatformConfigurationFactor y, org.eclipse.osgi.service.datalocation.Location, org.osgi.service.packageadmin.PackageAdmin, org.osgi.service.startlevel.StartLevel, java.lang.ClassLoader, org.eclipse.equinox.app.IApplicationContext, org.eclipse.osgi.internal.provisional.verifier.CertificateVe rifierFactory, org.osgi.service.prefs.PreferencesService, org.eclipse.osgi.service.security.TrustEngine, org.osgi.service.permissionadmin.PermissionAdmin, org.eclipse.osgi.signedcontent.SignedContentFactory, org.osgi.service.application.ApplicationDescriptor, org.osgi.service.url.URLStreamHandlerService, org.eclipse.osgi.framework.console.CommandProvider, org.eclipse.core.resources.IWorkspace, org.eclipse.pde.core.project.IBundleProjectService, org.osgi.service.application.ApplicationHandle, org.osgi.service.condpermadmin.ConditionalPermissionAdmin]
Do you know who is responsible to register service for class org.eclipse.equinox.internal.provisional.frameworkadmin.Fram eworkAdmin?
Current Time: Thu Apr 25 22:39:34 GMT 2024
Powered by FUDForum. Page generated in 0.03400 seconds
