Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » For those using Teneo from cvs: HEAD is Teneo for EMF 2.3 , Branch: R0_7_maintenance is EMF 2.2
For those using Teneo from cvs: HEAD is Teneo for EMF 2.3 , Branch: R0_7_maintenance is EMF 2.2 [message #602289] Wed, 07 February 2007 17:12
Martin Taal is currently offline Martin TaalFriend
For those using Teneo from cvs. I am working on upgrading Teneo to EMF 2.3/jdk 1.5. The related
changes are being made in cvs HEAD.
The EMF 2.2 release of Teneo is from now maintained in the R0_7_maintenance branch.
To switch your current version to the maintenance branch right click on each project and select:
Replace With > Another Branch or Version
Click Refresh Tags and the R0_7_maintenance branch should show up, select it and click ok.
I will be doing builds for both EMF 2.2 and EMF 2.3. The EMF 2.2 builds with be called maintenance
builds (build id starts with M), the EMF 2.3 builds will be so-called integration build (build id
starts with I).
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Previous Topic:[Announce] EclipseCon 2007 Registration
Next Topic:[Teneo] IdentifierCacheHandler does not work for EObjects with hashCode implementations
Current Time: Sat Oct 31 05:32:24 GMT 2020
Powered by FUDForum. Page generated in 0.02110 seconds
