Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » JET error
JET error [message #600520] Wed, 03 January 2007 08:41
Originally posted by: rtv222.gmail.com
I am using JET to generate code from an EMF model.
I have done the following steps on my JET transformation project and I have
a ecore model
created by importing the example library.xsd
a.. Open the plugin.xml file in the root of the JET transformation
project.
b.. Switch to the 'Extensions' tab.
c.. Find the 'org.eclipse.jet.transform' extension in the 'All Extensions'
tree, and expand it to reveal the 'transform' child element.
d.. Select the 'transform' element, and enter org.eclipse.jet.xml in the
'modelLoader' field.
However, on attempting to run a simple JET template
<%@taglib prefix="c" id="org.eclipse.jet.controlTags" %>
<c:load url="library.xml" var="pluginXML"/>
package org.book;
class <c:get select="$library/books/@title" />Person {
public String getTitle() {
return "<c:get select="$library/books/@title" />";
public String getAuthor() {
return "<c:get select="$library/books/@author" />";
I get the following error.
Exception in thread "main" java.lang.NullPointerException
org.eclipse.jet.taglib.TagLibraryManager.getTagLibrary(TagLi braryManager.java:89)
org.eclipse.jet.internal.runtime.TagFactoryImpl.createRuntim eTag(TagFactoryImpl.java:61)
at jet2java.Transform$1.createRuntimeTag(Transform.java:33)
at org.eclipse.jet.compiled._jet_test.generate(_jet_test.java:5 4)
at jet2java.Transform.main(Transform.java:149)
Pls let me know what I could be doing wrong.
Rgds,
Rajesh
Previous Topic:teneo - @OrderBy not processed?
Next Topic:Using JET on xsd compliant xml
Current Time: Thu Feb 25 22:28:06 GMT 2021
Powered by FUDForum. Page generated in 0.01748 seconds
