Home » Language IDEs » ServerTools (WTP) » Newbie question: How to use SAX with Eclipse?
Newbie question: How to use SAX with Eclipse? [message #5353] Sun, 22 June 2003 17:33 Go to next message
Originally posted by: sunifyre.yahoo.com
I'm trying to develop a SAX application to read and parse an XML document
and output it to another file. However, I can't seem to figure out which
parser to use in Eclipse in the XMLReader object.
As it is, what I have done so far:
package xml2;
import org.xml.sax.*;
//Default parser to use
private String parserClass= "org.apache.xerces.parsers.SAXParser";
//Create instances needed for parsing
XMLReader reader = XMLReaderFactory.createXMLReader(parserClass);
//rest of code
For some reason, while this code compiles, it gives me a runtime error:
java.lang.ClassNotFoundException: org.apache.xerces.parsers.SAXParser
org.xml.sax.helpers.XMLReaderFactory.createXMLReader(XMLRead erFactory.java:1
21)
at SAXTreeViewer.buildTree(SAXTreeViewer.java:49)
at SAXTreeViewer.init(SAXTreeViewer.java:38)
at SAXTreeViewer.main(SAXTreeViewer.java:66
Anyone have any suggestions, comments, advice please?
Sunitha Kumar
sunifyre@nospam.yahoo.com
Re: Newbie question: How to use SAX with Eclipse? [message #5403 is a reply to message #5353] Sun, 22 June 2003 17:52 Go to previous messageGo to next message
Hi Sunitha,
> package xml2;
> //rest of code
> at
> 21)
Looks like a classpath problem. First of all you have created a java
project.
Then you placed your code in. Next step is to add the external libs (like
your xerces
parser). As far as I remember it the createXMLReader method uses forName
therefore
it wont through an compile exception on runtime.
You can add additional libraries in preferences of the project(project
contextmenu
(leftclick on project)). I think that helps.
Another solution is to stop using xerces and use the xml facility which is
shipped with
SDK 1.4. Look at the xml tutorial at java.sun.com.
I hope I could provide a solution,
Martin (Kersten)
Re: Newbie question: How to use SAX with Eclipse? [message #5408 is a reply to message #5403] Sun, 22 June 2003 18:13 Go to previous message
"Martin Kersten" <Martin.Kersten@student.uni-magdeburg.de> wrote in message
news:bd58cm$6bn$1@rogue.oti.com...
> shipped with SDK 1.4. Look at the xml tutorial at java.sun.com.
Thanks, Martin - I'll try that
Previous Topic:XML tree viewer source
Next Topic:What is Web tools
Current Time: Sat Jul 19 14:08:57 EDT 2025
Powered by FUDForum. Page generated in 0.03664 seconds
