Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE director throws signature exception
PDE director throws signature exception [message #595138] Wed, 15 April 2009 01:42
Originally posted by: wbeckwith.gmail.com
I'm trying to build an rcp and once I gor through all the missing
dependencies, pde build is throwing the following stacktrace. There are
no other processes touching the files so I don't see why it thinks they
have been modified.
main:
runDirector:
runDirector:
[java] !SESSION 2009-04-14 17:34:03.145
[java] eclipse.buildId=I20090313-0100
[java] java.version=1.5.0_17
[java] java.vendor=Sun Microsystems Inc.
[java] BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
[java] Framework arguments: -application
org.eclipse.equinox.p2.director.app.application
--launcher.suppressErrors -flavor tooling -installIU
com.itko.lisa.workstation.product -version 1.0.0 -p2.os win32 -p2.ws
win32 -p2.arch x86 -roaming -profile profile -profileProperties
org.eclipse.update.install.features=true -metadataRepository
file:D:\dev\workspace-main\lisa-product.builder/build/buildR epo
-artifactRepository
-destination
D:\dev\workspace-main\lisa-product.builder/build/tmp/eclipse -bundlepool
[java] Command-line arguments: -application
--launcher.suppressErrors -consoleLog -flavor tooling -installIU
-artifactRepository
-destination
[java]
[java] !ENTRY org.eclipse.equinox.registry 2 0 2009-04-14 17:34:05.718
[java] !MESSAGE The extensions and extension-points from the
bundle "org.eclipse.gmf.runtime.common.ui.printing.win32" are ignored.
The host bundle "org.eclipse.gmf.runtime.common.ui.printing" is not
marked as singleton.
[java]
[java] !ENTRY org.eclipse.equinox.registry 2 0 2009-04-14 17:34:05.890
bundle "com.eviware.soapui.libs" are ignored. The bundle is not marked
as singleton.
[java] Installing com.itko.lisa.workstation.product 1.0.0.
[java]
[java] !ENTRY org.eclipse.osgi 4 0 2009-04-14 17:34:09.112
[java] !MESSAGE Either the manifest file or the signature file has
been tampered in this jar:
C:\Users\Wendell\AppData\Local\Temp\signatureFile25866179671 50348418.jar
[java] !STACK 0
[java] java.security.SignatureException: Either the manifest file
or the signature file has been tampered in this jar:
[java] at
org.eclipse.osgi.internal.signedcontent.SignatureBlockProces sor.verifyManifestAndSignatureFile(SignatureBlockProcessor.j ava:154)
[java] at
org.eclipse.osgi.internal.signedcontent.SignatureBlockProces sor.processSigner(SignatureBlockProcessor.java:104)
[java] at
org.eclipse.osgi.internal.signedcontent.SignatureBlockProces sor.process(SignatureBlockProcessor.java:60)
[java] at
org.eclipse.osgi.internal.signedcontent.SignedBundleFile.set BundleFile(SignedBundleFile.java:47)
[java] at
org.eclipse.osgi.internal.signedcontent.SignedBundleHook.get SignedContent(SignedBundleHook.java:245)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.Signatur eVerifier.verifyContent(SignatureVerifier.java:77)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.Signatur eVerifier.verify(SignatureVerifier.java:59)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.Signatur eVerifier.close(SignatureVerifier.java:100)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.reportStatus(SimpleArtifactRepositor y.java:838)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.downloadArtifact(SimpleArtifactRepos itory.java:447)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:513)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transferSingle(MirrorRequest.java:169)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.transfer(MirrorRequest.java:153)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.MirrorRe quest.perform(MirrorRequest.java:94)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifact(SimpleArtifactRepository .java:502)
[java] at
org.eclipse.equinox.internal.p2.artifact.repository.simple.S impleArtifactRepository.getArtifacts(SimpleArtifactRepositor y.java:558)
[java] at
org.eclipse.equinox.internal.p2.engine.DownloadManager.fetch (DownloadManager.java:108)
[java] at
org.eclipse.equinox.internal.p2.engine.DownloadManager.start (DownloadManager.java:96)
[java] at
org.eclipse.equinox.internal.provisional.p2.engine.phases.Co llect.completePhase(Collect.java:72)
[java] at
org.eclipse.equinox.internal.provisional.p2.engine.Phase.pos tPerform(Phase.java:162)
[java] at
org.eclipse.equinox.internal.provisional.p2.engine.Phase.per form(Phase.java:68)
[java] at
org.eclipse.equinox.internal.provisional.p2.engine.PhaseSet. perform(PhaseSet.java:44)
[java] at
org.eclipse.equinox.internal.provisional.p2.engine.Engine.pe rform(Engine.java:51)
[java] at
org.eclipse.equinox.internal.p2.director.app.Application.pla nAndExecute(Application.java:257)
[java] at
org.eclipse.equinox.internal.p2.director.app.Application.run (Application.java:412)
[java] at
org.eclipse.equinox.internal.p2.director.app.Application.sta rt(Application.java:509)
[java] at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
[java] at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
[java] at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
[java] at
[java] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
[java] at
[java] at
[java] at java.lang.reflect.Method.invoke(Method.java:585)
[java] at
org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 556)
[java] at org.eclipse.equinox.launcher.Main.basicRun(Main.java:511)
[java] at org.eclipse.equinox.launcher.Main.run(Main.java:1284)
[java] at org.eclipse.equinox.launcher.Main.main(Main.java:1260)
[java]
[java] !ENTRY org.eclipse.osgi 4 0 2009-04-14 17:34:09.164
C:\Users\Wendell\AppData\Local\Temp\signatureFile46244257412 87687720.jar
[java] !STACK 0
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java]
[java] !ENTRY org.eclipse.osgi 4 0 2009-04-14 17:34:09.216
C:\Users\Wendell\AppData\Local\Temp\signatureFile83840254105 68259577.jar
[java] !STACK 0
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java]
[java] !ENTRY org.eclipse.osgi 4 0 2009-04-14 17:34:09.310
C:\Users\Wendell\AppData\Local\Temp\signatureFile21520669671 22439990.jar
[java] !STACK 0
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java] at
[java]
Wb
Previous Topic:Build Error: ${launcherName}.app\Contents\MacOS not found
Next Topic:Plug-in View: Import As | Source Project
Current Time: Sat Jun 19 16:12:53 GMT 2021
Powered by FUDForum. Page generated in 0.01994 seconds
