Save files twice [message #590025] |
Mon, 10 February 2003 13:01 |
Dagmar Buggle Messages: 3 Registered: October 2009 |
Junior Member |
I'm working on Win NT 4.0 and my source files are under ClearCase CM.
Formerly I worked with jbuilder7, from there I took my directory structure
and made an eclipse project out of these files. The whole thing works
quite well so far, but there is one annoying limitation: I am able to save
each file after changing it only once. If I'm adding another change and
want to save the file again, the following message will be displayed:
Save could not be completed
Reason:
Resource is out of sync with the file system.
The thing works, if I close the file without saving and reopen it or
simply refresh the file after saving. But this is rather annoying, and I
think, it should be possible to save whenever i feel the need to do so.
Am I doing something wrong? Is there a setting which is not set properly?
Or is it a feature?
Thanks, Dagmar
FUDForum. Page generated in 0.01445 seconds
