Plugin wizard sets up platform-dependent classpath [message #588582] |
Sun, 12 January 2003 00:25 |
Peter Nehrer Messages: 241 Registered: July 2009 |
I'm seeking some guidance on this not-so-serious issue. I'm developing a
plugin that provides (so far) an incremental builder and some popup menus.
I created the project using the plugin wizard -- default plugin -- on
Windows 2000. When I then imported the project on my Linux box (same
Eclipse build - M4), I got two "dependencies missing" from classpath: 1). a
win32-specific swt.jar and 2).
org.eclipse.ui.win32_2.1.0/workbenchwin32.jar. The first one is easy to fix
-- point to linux/motif swt.jar. However, the second one doesn't seem to
have an equivalent (though the project builds fine on Linux without it).
Should the wizard be fixed up to set up platform-independent classpath
variables? Is there a different solution? Should I have done something
differently?
Thanks!
--Peter
FUDForum. Page generated in 0.02492 seconds
