Project set file for SVN checkout [message #581704] |
Mon, 09 February 2009 18:53 |
Tom Morris Messages: 89 Registered: July 2009 |
Member |
--------------010700050501010508050004
Attached is a project set file which may be useful for developers (not
Papyrus users) to simplify checkout from SVN. It only checks out the
core and uml directories, but there are two other directories (dev and
other) which you may be interested in exploring on your own. This will
at least get you started with the right version of ANTLR and the basic
set of plugins.
Tom
p.s. Eclipse PSFs are specific to your SVN plugin (ick!) and I use
Subversion, so if you use Subclipse you'll either need to modify the PSF
or check out the projects by hand.
Content-Type: text/xml;
name="papyrus-core+uml-projectSet.psf"
Content-Disposition: inline;
filename="papyrus-core+uml-projectSet.psf"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4NCjxwc2Yg dmVyc2lvbj0i
Mi4wIj4NCjxwcm92aWRlciBpZD0ib3JnLnRpZ3Jpcy5zdWJ2ZXJzaW9uLnN1 YmNsaXBzZS5j
b3JlLnN2bm5hdHVyZSI+DQo8cHJvamVjdCByZWZlcmVuY2U9IjAuOS4zLGh0 dHA6Ly9kZXYu
ZWNsaXBzZS5vcmcvc3Zucm9vdC9tb2RlbGluZy9vcmcuZWNsaXBzZS5tZHQu cGFweXJ1cy90
cnVuay9wbHVnaW5zL2NvcmUvb3JnLmVjbGlwc2UucGFweXJ1cy5jb3JlLG9y Zy5lY2xpcHNl
LnBhcHlydXMuY29yZSIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIwLjkuMyxo dHRwOi8vZGV2
LmVjbGlwc2Uub3JnL3N2bnJvb3QvbW9kZWxpbmcvb3JnLmVjbGlwc2UubWR0 LnBhcHlydXMv
dHJ1bmsvcGx1Z2lucy9jb3JlL29yZy5lY2xpcHNlLnBhcHlydXMuY29yZS5h ZGFwdG9yLmVt
ZixvcmcuZWNsaXBzZS5wYXB5cnVzLmNvcmUuYWRhcHRvci5lbWYiLz4NCjxw cm9qZWN0IHJl
ZmVyZW5jZT0iMC45LjMsaHR0cDovL2Rldi5lY2xpcHNlLm9yZy9zdm5yb290 L21vZGVsaW5n
L29yZy5lY2xpcHNlLm1kdC5wYXB5cnVzL3RydW5rL3BsdWdpbnMvY29yZS9v cmcuZWNsaXBz
ZS5wYXB5cnVzLmNvcmUuYWRhcHRvci5nbWYsb3JnLmVjbGlwc2UucGFweXJ1 cy5jb3JlLmFk
YXB0b3IuZ21mIi8+DQo8cHJvamVjdCByZWZlcmVuY2U9IjAuOS4zLGh0dHA6 Ly9kZXYuZWNs
aXBzZS5vcmcvc3Zucm9vdC9tb2RlbGluZy9vcmcuZWNsaXBzZS5tZHQucGFw eXJ1cy90cnVu
ay9wbHVnaW5zL2NvcmUvb3JnLmVjbGlwc2UucGFweXJ1cy5jb3JlLmZlYXR1 cmUsb3JnLmVj
bGlwc2UucGFweXJ1cy5jb3JlLmZlYXR1cmUiLz4NCjxwcm9qZWN0IHJlZmVy ZW5jZT0iMC45
LjMsaHR0cDovL2Rldi5lY2xpcHNlLm9yZy9zdm5yb290L21vZGVsaW5nL29y Zy5lY2xpcHNl
Lm1kdC5wYXB5cnVzL3RydW5rL3BsdWdpbnMvY29yZS9vcmcuZWNsaXBzZS5w YXB5cnVzLmRp
LG9yZy5lY2xpcHNlLnBhcHlydXMuZGkiLz4NCjxwcm9qZWN0IHJlZmVyZW5j ZT0iMC45LjMs
aHR0cDovL2Rldi5lY2xpcHNlLm9yZy9zdm5yb290L21vZGVsaW5nL29yZy5l Y2xpcHNlLm1k
dC5wYXB5cnVzL3RydW5rL3BsdWdpbnMvY29yZS9vcmcuZWNsaXBzZS5wYXB5 cnVzLmRpLmVk
aXQsb3JnLmVjbGlwc2UucGFweXJ1cy5kaS5lZGl0Ii8+DQo8cHJvamVjdCBy ZWZlcmVuY2U9
IjAuOS4zLGh0dHA6Ly9kZXYuZWNsaXBzZS5vcmcvc3Zucm9vdC9tb2RlbGlu Zy9vcmcuZWNs
aXBzZS5tZHQucGFweXJ1cy90cnVuay9wbHVnaW5zL2NvcmUvb3JnLmVjbGlw c2UucGFweXJ1
cy5kaS5lZGl0b3Isb3JnLmVjbGlwc2UucGFweXJ1cy5kaS5lZGl0b3IiLz4N Cjxwcm9qZWN0
IHJlZmVyZW5jZT0iMC45LjMsaHR0cDovL2Rldi5lY2xpcHNlLm9yZy9zdm5y b290L21vZGVs
aW5nL29yZy5lY2xpcHNlLm1kdC5wYXB5cnVzL3RydW5rL3BsdWdpbnMvdW1s L29yZy5lY2xp
cHNlLnBhcHlydXMuZGlhZ3JhbS5hY3Rpdml0eSxvcmcuZWNsaXBzZS5wYXB5 cnVzLmRpYWdy
YW0uYWN0aXZpdHkiLz4NCjxwcm9qZWN0IHJlZmVyZW5jZT0iMC45LjMsaHR0 cDovL2Rldi5l
Y2xpcHNlLm9yZy9zdm5yb290L21vZGVsaW5nL29yZy5lY2xpcHNlLm1kdC5w YXB5cnVzL3Ry
dW5rL3BsdWdpbnMvdW1sL29yZy5lY2xpcHNlLnBhcHlydXMuZGlhZ3JhbS5j bGF6eixvcmcu
ZWNsaXBzZS5wYXB5cnVzLmRpYWdyYW0uY2xhenoiLz4NCjxwcm9qZWN0IHJl ZmVyZW5jZT0i
MC45LjMsaHR0cDovL2Rldi5lY2xpcHNlLm9yZy9zdm5yb290L21vZGVsaW5n L29yZy5lY2xp
cHNlLm1kdC5wYXB5cnVzL3RydW5rL3BsdWdpbnMvdW1sL29yZy5lY2xpcHNl LnBhcHlydXMu
ZGlhZ3JhbS5jb21tb24sb3JnLmVjbGlwc2UucGFweXJ1cy5kaWFncmFtLmNv bW1vbiIvPg0K
PHByb2plY3QgcmVmZXJlbmNlPSIwLjkuMyxodHRwOi8vZGV2LmVjbGlwc2Uu b3JnL3N2bnJv
b3QvbW9kZWxpbmcvb3JnLmVjbGlwc2UubWR0LnBhcHlydXMvdHJ1bmsvcGx1 Z2lucy91bWwv
b3JnLmVjbGlwc2UucGFweXJ1cy5kaWFncmFtLmVtZnRyZWUsb3JnLmVjbGlw c2UucGFweXJ1
cy5kaWFncmFtLmVtZnRyZWUiLz4NCjxwcm9qZWN0IHJlZmVyZW5jZT0iMC45 LjMsaHR0cDov
L2Rldi5lY2xpcHNlLm9yZy9zdm5yb290L21vZGVsaW5nL29yZy5lY2xpcHNl Lm1kdC5wYXB5
cnVzL3RydW5rL3BsdWdpbnMvdW1sL29yZy5lY2xpcHNlLnBhcHlydXMuZGlh Z3JhbS5zZXF1
ZW5jZSxvcmcuZWNsaXBzZS5wYXB5cnVzLmRpYWdyYW0uc2VxdWVuY2UiLz4N Cjxwcm9qZWN0
cHNlLnBhcHlydXMuZGlhZ3JhbS51c2VjYXNlLG9yZy5lY2xpcHNlLnBhcHly dXMuZGlhZ3Jh
bS51c2VjYXNlIi8+DQo8cHJvamVjdCByZWZlcmVuY2U9IjAuOS4zLGh0dHA6 Ly9kZXYuZWNs
ay9wbHVnaW5zL2NvcmUvb3JnLmVjbGlwc2UucGFweXJ1cy5leHRlbnNpb25w b2ludHMuZWRp
dG9ycyxvcmcuZWNsaXBzZS5wYXB5cnVzLmV4dGVuc2lvbnBvaW50cy5lZGl0 b3JzIi8+DQo8
cHJvamVjdCByZWZlcmVuY2U9IjAuOS4zLGh0dHA6Ly9kZXYuZWNsaXBzZS5v cmcvc3Zucm9v
dC9tb2RlbGluZy9vcmcuZWNsaXBzZS5tZHQucGFweXJ1cy90cnVuay9wbHVn aW5zL3VtbC9v
cmcuZWNsaXBzZS5wYXB5cnVzLm91dGxpbmUuZW1mdHJlZSxvcmcuZWNsaXBz ZS5wYXB5cnVz
Lm91dGxpbmUuZW1mdHJlZSIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIwLjku MyxodHRwOi8v
ZGV2LmVjbGlwc2Uub3JnL3N2bnJvb3QvbW9kZWxpbmcvb3JnLmVjbGlwc2Uu bWR0LnBhcHly
dXMvdHJ1bmsvcGx1Z2lucy91bWwvb3JnLmVjbGlwc2UucGFweXJ1cy5wYXJz ZXJzLG9yZy5l
Y2xpcHNlLnBhcHlydXMucGFyc2VycyIvPg0KPHByb2plY3QgcmVmZXJlbmNl PSIwLjkuMyxo
dHRwOi8vZGV2LmVjbGlwc2Uub3JnL3N2bnJvb3QvbW9kZWxpbmcvb3JnLmVj bGlwc2UubWR0
LnBhcHlydXMvdHJ1bmsvcGx1Z2lucy9jb3JlL29yZy5lY2xpcHNlLnBhcHly dXMucHJlZmVy
ZW5jZXMsb3JnLmVjbGlwc2UucGFweXJ1cy5wcmVmZXJlbmNlcyIvPg0KPHBy b2plY3QgcmVm
ZXJlbmNlPSIwLjkuMyxodHRwOi8vZGV2LmVjbGlwc2Uub3JnL3N2bnJvb3Qv bW9kZWxpbmcv
b3JnLmVjbGlwc2UubWR0LnBhcHlydXMvdHJ1bmsvcGx1Z2lucy9jb3JlL29y Zy5lY2xpcHNl
LnBhcHlydXMuc2FzaGVkaXRvcixvcmcuZWNsaXBzZS5wYXB5cnVzLnNhc2hl ZGl0b3IiLz4N
Cjxwcm9qZWN0IHJlZmVyZW5jZT0iMC45LjMsaHR0cDovL2Rldi5lY2xpcHNl Lm9yZy9zdm5y
b290L21vZGVsaW5nL29yZy5lY2xpcHNlLm1kdC5wYXB5cnVzL3RydW5rL3Bs dWdpbnMvdW1s
L29yZy5lY2xpcHNlLnBhcHlydXMudGFiYmVkcHJvcGVydGllcy5hcHBlYXJh bmNlLG9yZy5l
Y2xpcHNlLnBhcHlydXMudGFiYmVkcHJvcGVydGllcy5hcHBlYXJhbmNlIi8+ DQo8cHJvamVj
dCByZWZlcmVuY2U9IjAuOS4zLGh0dHA6Ly9kZXYuZWNsaXBzZS5vcmcvc3Zu cm9vdC9tb2Rl
bGluZy9vcmcuZWNsaXBzZS5tZHQucGFweXJ1cy90cnVuay9wbHVnaW5zL2Nv cmUvb3JnLmVj
bGlwc2UucGFweXJ1cy50YWJiZWRwcm9wZXJ0aWVzLmNvcmUsb3JnLmVjbGlw c2UucGFweXJ1
cy50YWJiZWRwcm9wZXJ0aWVzLmNvcmUiLz4NCjxwcm9qZWN0IHJlZmVyZW5j ZT0iMC45LjMs
dC5wYXB5cnVzL3RydW5rL3BsdWdpbnMvdW1sL29yZy5lY2xpcHNlLnBhcHly dXMudGFiYmVk
cHJvcGVydGllcy51bWwsb3JnLmVjbGlwc2UucGFweXJ1cy50YWJiZWRwcm9w ZXJ0aWVzLnVt
bCIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIwLjkuMyxodHRwOi8vZGV2LmVj bGlwc2Uub3Jn
L3N2bnJvb3QvbW9kZWxpbmcvb3JnLmVjbGlwc2UubWR0LnBhcHlydXMvdHJ1 bmsvcGx1Z2lu
cy91bWwvb3JnLmVjbGlwc2UucGFweXJ1cy51aS50b29sYm94LG9yZy5lY2xp cHNlLnBhcHly
dXMudWkudG9vbGJveCIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIwLjkuMyxo dHRwOi8vZGV2
dHJ1bmsvcGx1Z2lucy91bWwvb3JnLmVjbGlwc2UucGFweXJ1cy51bWwuZmVh dHVyZSxvcmcu
ZWNsaXBzZS5wYXB5cnVzLnVtbC5mZWF0dXJlIi8+DQo8cHJvamVjdCByZWZl cmVuY2U9IjAu
OS4zLGh0dHA6Ly9kZXYuZWNsaXBzZS5vcmcvc3Zucm9vdC9tb2RlbGluZy9v cmcuZWNsaXBz
ZS5tZHQucGFweXJ1cy90cnVuay9wbHVnaW5zL3VtbC9vcmcuZWNsaXBzZS5w YXB5cnVzLnVt
bHV0aWxzLG9yZy5lY2xpcHNlLnBhcHlydXMudW1sdXRpbHMiLz4NCjxwcm9q ZWN0IHJlZmVy
ZW5jZT0iMC45LjMsaHR0cDovL2Rldi5lY2xpcHNlLm9yZy9zdm5yb290L21v ZGVsaW5nL29y
Zy5lY2xpcHNlLm1kdC5wYXB5cnVzL3RydW5rL3BsdWdpbnMvY29yZS9vcmcu ZWNsaXBzZS5w
YXB5cnVzLndpemFyZHMsb3JnLmVjbGlwc2UucGFweXJ1cy53aXphcmRzIi8+ DQo8L3Byb3Zp
ZGVyPg0KPHByb3ZpZGVyIGlkPSJvcmcuZWNsaXBzZS50ZWFtLmN2cy5jb3Jl LmN2c25hdHVy
ZSI+DQo8cHJvamVjdCByZWZlcmVuY2U9IjEuMCw6cHNlcnZlcjpkZXYuZWNs aXBzZS5vcmc6
L2N2c3Jvb3QvdG9vbHMsb3JnLmVjbGlwc2Uub3JiaXQvb3JnLmFudGxyLnJ1 bnRpbWUsb3Jn
LmFudGxyLnJ1bnRpbWUsdjNfMF8wIi8+DQo8L3Byb3ZpZGVyPg0KPC9wc2Y+
--------------010700050501010508050004--
FUDForum. Page generated in 0.01944 seconds
