epsilon 0.8.5 generation problem [message #567321] |
Thu, 30 April 2009 11:57 |
Dmitriy N. Messages: 7 Registered: July 2009 |
Junior Member |
after i updated to version 0.8.5 I keep getting the exception below every
time I use eugenia gmf generator. ecore file was not changed from 0.8.4
and did work perfect with old version. any idea how to make it work? I
lost my 0.8.4 installation, is there any way to download 0.8.4 version
from somewhere?
thanks,
Dmitriy
EXCEPTION:
Internal error: java.lang.ArrayStoreException
at org.eclipse.emf.common.util.BasicEList.assign[BasicEList.jav a:191]
at org.eclipse.emf.common.util.BasicEList.addUnique[BasicEList. java:645]
org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddUn ique[NotifyingListImpl.java:331]
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue[NotifyingListImpl.java:288]
at org.eclipse.emf.common.util.BasicEList.add[BasicEList.java:6 26]
at org.eclipse.epsilon.eol.types.EolSet.addAll[EolSet.java:47]
at sun.reflect.NativeMethodAccessorImpl.invoke0[Native Method]
at sun.reflect.NativeMethodAccessorImpl.invoke[Unknown Source]
at sun.reflect.DelegatingMethodAccessorImpl.invoke[Unknown Source]
at java.lang.reflect.Method.invoke[Unknown Source]
org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod[Re flectionUtil.java:123]
org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod[Re flectionUtil.java:99]
org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on[PointExecutor.java:179]
org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:66]
org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:36]
org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:122]
org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST[E xecutorFactory.java:184]
org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te[StatementBlockExecutor.java:33]
org.eclipse.epsilon.eol.execute.ForStatementExecutor.execute [ForStatementExecutor.java:115]
at org.eclipse.epsilon.eol.EolModule.execute[EolModule.java:57]
org.eclipse.epsilon.eugenia.EolTransformationActionDelegate. runImpl[EolTransformationActionDelegate.java:102]
org.eclipse.epsilon.eugenia.EolTransformationActionDelegate$ 1.run[EolTransformationActionDelegate.java:56]
at org.eclipse.core.internal.jobs.Worker.run[Worker.java:55]
(155:33)
at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.jav a:191)
at org.eclipse.emf.common.util.BasicEList.addUnique(BasicEList. java:645)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.doAddUn ique(NotifyingListImpl.java:331)
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addUniq ue(NotifyingListImpl.java:288)
at org.eclipse.emf.common.util.BasicEList.add(BasicEList.java:6 26)
at org.eclipse.epsilon.eol.types.EolSet.addAll(EolSet.java:47)
org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod(Re flectionUtil.java:123)
org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod(Re flectionUtil.java:99)
org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on(PointExecutor.java:179)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:66)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:36)
org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:122)
org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(E xecutorFactory.java:184)
org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te(StatementBlockExecutor.java:33)
org.eclipse.epsilon.eol.execute.ForStatementExecutor.execute (ForStatementExecutor.java:115)
at org.eclipse.epsilon.eol.EolModule.execute(EolModule.java:57)
org.eclipse.epsilon.eugenia.EolTransformationActionDelegate. runImpl(EolTransformationActionDelegate.java:102)
org.eclipse.epsilon.eugenia.EolTransformationActionDelegate$ 1.run(EolTransformationActionDelegate.java:56)
FUDForum. Page generated in 0.02578 seconds
