Click on one, insert in another [message #57002] |
Thu, 28 September 2006 07:13  |
Originally posted by: tobk.gmx.de
is there a way to have a newly created item inserted in a different element
than the one the user clicked on? I tried out the children-feature, but I
do not get any features of this element's childs...
Here are the two situations. I'll model the containment structure and
annotate what item has to be clicked on and where the new item shall be
inserted.
a)
Subprocess <- click here
+-EmbeddedSubprocessAttributeSet
+-GraphicalElements <- insert here
b)
Pool
+-Process (unique)
+-Lane <-click here
Tobias
Re: Click on one, insert in another [message #57531 is a reply to message #57452] |
Fri, 29 September 2006 08:51   |
Right, XXXItemSemanticEditPolicy is the place to fix.
1. req.setContainmentFeature() is self-description. put correct metafeature
here (Pool_Process i suspect)
2. CreateXXXCommand - modify getEClassToEdit to point to owner of
containment feature from (1).
3. Fix getElementToEdit() method - navigate to the appropriate element (e.g.
Lane.getParentPool())
These midifications control only changes in the domain model, placement of
grapical elements should happen according to addChildVisual() logic in
appropriate edit parts.
As for move and delete, there should be no additional efforts (container
element is known at the time of removal)
Artem
"tobias" <tobk@gmx.de> wrote in message
news:efj12h$blm$1@utils.eclipse.org...
> Artem Tikhomirov wrote:
>> You'll need to modify creation command, gmfmap's children feature is not
>> for that usecase.
>> Artem
> Ok, so I'd have to create a pseudo-containment-feature for the Class I
> want
> to click on, so the right editParts and polcies are created. Later, the
> pseudo-containment-feature would has to be removed again (or just
> ignored).
> I took a look at the CompartmentItemSemanticEditPolicy. There a constant
> is
> used to specify where to put stuff in (similar to the gmpmap). I doubt
> that
> I can What method do I have to override to specify where to put it, when
> it
> is not a feature of the class itself [1]? Execute? And could you point out
> or send me a reference where else I would have to make changes, like for
> moving or deleting the created element?
> Tobias
> [1] As I said: I want to click on a "Lane" and insert the new Element in
> the
> collection Lane.getParentPool().getProcess().getGraphicalElements()
Re: Click on one, insert in another [message #57726 is a reply to message #57531] |
Fri, 29 September 2006 16:52  |
> metafeature here (Pool_Process i suspect)
> (e.g. Lane.getParentPool())
> Artem
Thanks, it works well for creation and delition, but when I move an element
it is reinserted in the pseudoElements-Feature (which is bad...). I think
I'll just keep my eyes open for occurances of the pseudoElements-Feature
and sooner or later I'll find the place to edit - but if anyone already
knows, please tell me! *g*
tobias
By the way, I mentioned a kinda strange behaviour of the generator: Most of
my elements can be inserted in two containers, which, as we all know,
results in duplicate EditParts for these features. However, when I
generated the editor with the ChildReferences contained in the second
container while the original EditParts already existed the duplicates where
not generated. When I deleted and recreated the whole editor (to get rid of
junk code from former configurations) the duplicates where there again.
So maybe you can generally avoid the duplicates by creating the editor with
only the originals in the gmfmap, then pasting the reference-children in
the map and recreating the code.
FUDForum. Page generated in 0.12907 seconds
