One model + EGL; multiple targets [message #563623] |
Thu, 08 January 2009 18:07 |
No real name Messages: 92 Registered: July 2009 |
Member |
Hia there,
I was wondering whether anyone has any suggestions for my following
problem. Given a model (from someone else) that can contain an arbitrary
number of instances of the same meta class (e.g., x1, x2 and x3 are in the
model, and are instances of meta class X), I would like to print values
based on each of these instances (which I can find in the model), to
separate files -- for example, to x1.txt, x2.txt and x3.txt.
Since text needs to be printed, EGL seemed the sensible choice. The
difficulty I have is how to use EGL, when one model has been loaded, to
print to several target files... Do you know if this is possible, or
indeed, whether this approach is sensible? Any help would be very much
appreciated.
Thanks!
FUDForum. Page generated in 0.03061 seconds
