Loading multiple model instances, for translation [message #563093] |
Mon, 15 December 2008 11:27 |
No real name Messages: 92 Registered: July 2009 |
Member |
I've so far been using ETL to transform a model A to model B (through
Ant). In general, the transformation needs to be applied to several source
models of A, to progressively build up the target model (which
accommodates this). I guess this is a common scenario, but am not sure of
the right way to do it.. Any ideas? I assumed I'd be able to perform
<epsilon.loadModel name="A" ... to load the first instance of A, then
perform the translation, and then <epsilon.loadModel name="A" ... again,
to load the second instance of A, perform translation, etc. However, this
approach only loads the first instance of A. Any help/pointers would be
very handy.
Ta,
Edd
FUDForum. Page generated in 0.03136 seconds
