Starter error [message #562781] |
Fri, 05 December 2008 11:19 |
Jose Salazar Messages: 34 Registered: July 2009 |
Member |
I've eclipse Ganymede with GMF, EMF, EuGENia... lastest plugins. I've
tried to lunch an EuGENia project, but when I try to "Generate GMF tool,
graph and map models", I get the follow internal error trace:
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:3777)
at org.eclipse.swt.SWT.error(SWT.java:3695)
at org.eclipse.swt.SWT.error(SWT.java:3666)
at org.eclipse.swt.widgets.Widget.error(Widget.java:463)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:276)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:365)
at org.eclipse.jface.window.Window.createShell(Window.java:487)
at org.eclipse.jface.window.Window.create(Window.java:430)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
org.eclipse.jface.dialogs.MessageDialog.openError(MessageDia log.java:322)
org.eclipse.epsilon.eugenia.EolTransformationActionDelegate$ 1.run(EolTransformationActionDelegate.java:57)
Any idea?
Thanks.
FUDForum. Page generated in 0.04721 seconds
