Re: project wizard and launch configuration [message #559606 is a reply to message #559367] |
Fri, 17 September 2010 11:23 |
jeremie Messages: 233 Registered: April 2010 |
I am close to resolve the problem :
To add a menu, I add this in the plugin..xml of the ui project :
<!-- popup menu -->
<extension
point="org.eclipse.ui.commands">
<command
description="Trigger expensive validation"
id="fr.irisa.cairn.graphAdapter.Language.generateAdapter"
name="generate adapter">
</command>
</extension>
<extension
point="org.eclipse.ui.handlers">
<handler
class="fr.irisa.cairn.graphAdapter.ui.GraphAdapterGeneratorHandler"
commandId="fr.irisa.cairn.graphAdapter.Language.generateAdapter">
</handler>
</extension>
<extension point="org.eclipse.ui.menus">
<menuContribution
locationURI="popup:#TextEditorContext?after=group.edit">
<command
style="push"
tooltip="generate the graph adapter">
<visibleWhen checkEnabled="false">
<reference
definitionId="fr.irisa.cairn.graphAdapter.Language.Editor.opened">
</reference>
</visibleWhen>
</command>
</menuContribution>
</extension>
and I have created an Handler class which look like this :
public class GraphAdapterGeneratorHandler extends AbstractHandler {
// private final static String MODEL_PATH = "src/model/";
private final static String JAVA_PATH = "src-gen/";
private final static String ENCODING = "UTF-8";
// @Override
public Object execute(ExecutionEvent event) throws ExecutionException {
IFile adapterFile = getFilePath(event);
String modelPath = adapterFile.getProjectRelativePath().toOSString();
System.out.println("MODEL_PATH = " + modelPath);
GraphAdapterGenerator.generate(modelPath, JAVA_PATH, ENCODING);
return null;
and to launch the workflow, i have this int
the GraphAdapterGenerator class :
Mwe2Launcher.main(new String[] { "workflow.LanguageGenerator", "-p",
"modelPath=".concat(absoluteModelDir), "-p",
"targetDir=".concat(absoluteTargetDir), "-p",
"fileEncoding=".concat(this.encoding)
unfortunately it doen't work : when I run the generator project and create a new adapter project, if i want to lanch the generation, I have this exception:
0 [Thread-0] ERROR org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher - Couldn't find module with name 'workflow.LanguageGenerator'.
java.lang.IllegalArgumentException: Couldn't find module with name 'workflow.LanguageGenerator'.
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:63)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:76)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
at fr.irisa.cairn.graphAdapter.language.generator.GraphAdapterGenerator.run(GraphAdapterGenerator.java:108)
at fr.irisa.cairn.graphAdapter.language.generator.GraphAdapterGenerator.generate(GraphAdapterGenerator.java:25)
at fr.irisa.cairn.graphAdapter.ui.GraphAdapterGeneratorHandler.execute(GraphAdapterGeneratorHandler.java:27)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:820)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:806)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:796)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:3776)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1367)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1390)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1375)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1187)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3622)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3277)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2427)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:663)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
!ENTRY org.apache.log4j 4 0 2010-09-17 13:08:34.505
!MESSAGE org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher - Couldn't find module with name 'workflow.LanguageGenerator'.
That's strange because I still van launch the generation by a "manual way"
when I crete an adapter project, in the project I have this java file :
public class AdapterGenerator {
private final static String MODEL_PATH = "src/model/Model.adapt";
AdapterGenerator.generate();
public static void generate() {
GraphAdapterGenerator.generate(MODEL_PATH, JAVA_PATH, ENCODING);
This class replace the GraphAdapterGeneratorHandler class. And If I launch this file, the generation works.
For me, the 2 ways should works, but no.
Have you got any ideas?
Jérémie
Re: project wizard and launch configuration [message #559640 is a reply to message #559627] |
Fri, 17 September 2010 13:32 |
I tried to use de debugger, but I don"t have source for the Mwe2Launcher class, so it is not really clear what append in this class.
I tried to this :
Mwe2Launcher.main(new String[] { "platform:/plugin/fr.irisa.cairn.graphAdapter.language.generator/src/workflow/LanguageGenerator.mwe2", "-p",
// "tomPath=".concat(absoluteAdapterDir) });
but I have the same exception :
1 [Thread-0] ERROR org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher - Couldn't find module with name 'workflow.LanguageGenerator'.
But there is a difference, if I launch the generation with the old way, I have now, this exception :
MODEL_PATH = src/model/Model.adapt
1 ERROR Mwe2Launcher - java.net.MalformedURLException: unknown protocol: platform
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.net.MalformedURLException: unknown protocol: platform
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at org.eclipse.xtext.resource.SynchronizedXtextResourceSet.getResource(SynchronizedXtextResourceSet.java:23)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:47)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at hcdgAdapter.generator.AdapterGenerator.generate(AdapterGenerator.java:16)
at hcdgAdapter.generator.AdapterGenerator.main(AdapterGenerator.java:12)
Caused by: java.net.MalformedURLException: unknown protocol: platform
at java.net.URL.<init>(URL.java:574)
at java.net.URL.<init>(URL.java:464)
at java.net.URL.<init>(URL.java:413)
at org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInputStream(URIHandlerImpl.java:176)
at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:301)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1254)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
... 9 more
I don't understand why it is not the same comportement for the both way.
Jérémie
FUDForum. Page generated in 0.02841 seconds
