Home » Language IDEs » Java Development Tools (JDT) » problems with eclipse while programming android
problems with eclipse while programming android [message #559024] Wed, 15 September 2010 11:04 Go to next message
ian  is currently offline ian Friend
hi there
i am using eclipse 3.6 with java 1.6_21 in windows 7 64 bit
both eclipse and java are 64bit
every time i open eclipse it seems freezing every 2 secondes and i cant do any code in the taskmanager isee adb.exe after i close eclipse when i force close adb the eclipse stopped freezing but no connection to adb .
in short word i do every thing , reinstalling java , eclipse , android sdk
and ther no use .
i tried to edit ini file of eclipse by adding something after -vmargs
but its no use .
guys ineed this very badly for university course , please help
Re: problems with eclipse while programming android [message #559102 is a reply to message #559024] Wed, 15 September 2010 15:30 Go to previous messageGo to next message
Satyam Kandula is currently offline Satyam KandulaFriend
Did you try to use a different version of JVM? Eclipse has problems with atleast one patch version of 1.6_21.
Re: problems with eclipse while programming android [message #559112 is a reply to message #559102] Wed, 15 September 2010 16:07 Go to previous messageGo to next message
thnx for helping me
u mean 1.6_20 or lower
i searched the internet for downloadable ver of 1.6_20 for windows but with no any luck
i will be glad if you give me some links
Re: problems with eclipse while programming android [message #559116 is a reply to message #559112] Wed, 15 September 2010 16:28 Go to previous messageGo to next message
Look at http://wiki.eclipse.org/FAQ_How_do_I_run_Eclipse%3F.
Re: problems with eclipse while programming android [message #559124 is a reply to message #559116] Wed, 15 September 2010 16:37 Go to previous message
thnx
i downloaded 1.6_20 from the archive
Previous Topic:I can't install Eclipse!
Next Topic:Eclipse missing Android preferences
Current Time: Tue Apr 16 09:36:16 GMT 2024
Powered by FUDForum. Page generated in 1.22350 seconds
