Home » Modeling » TMF (Xtext) » errors after regeneration...
errors after regeneration... [message #558668] Mon, 13 September 2010 20:41 Go to next message
Henrik Lindberg is currently offline Henrik LindbergFriend
After regenerating the grammar for b3, I get guice errors, and it seems
to be related to:
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package
with uri 'null' not found. (classpath:/org/eclipse/b3/BeeLang.xmi, 297, 92)
What could be the cause of this?
- henrik
Re: errors after regeneration... [message #558671 is a reply to message #558668] Mon, 13 September 2010 20:59 Go to previous messageGo to next message
The significant change seems to be in
BeeLang.xmi, which in the previous version was:
<?xml version="1.0" encoding="ASCII"?>
But the newly generated has:
<?xml version="1.1" encoding="ASCII"?>
There where no other changes, and reverting to 1.0 made things work again.
Updating to latest nightly and testing again.
- henrik
On 9/13/10 10:41 PM, Henrik Lindberg wrote:
> to be related to:
> Regards
> - henrik
Re: errors after regeneration... [message #558677 is a reply to message #558671] Mon, 13 September 2010 21:39 Go to previous message
Upgrade to latest nightly solved the issue.
Sorry about the noise...
- henrik
> - henrik
>> to be related to:
>> 297, 92)
>> Regards
>> - henrik
Previous Topic:How to compare two xtext models
Next Topic:Implementation of AbstractScope.getAllContent() results in performance problem
Current Time: Tue Apr 16 15:18:50 GMT 2024
Powered by FUDForum. Page generated in 0.29671 seconds
