Re: Resolving proxy when processing xtext model [message #556479 is a reply to message #556470] |
Wed, 01 September 2010 14:12 |
i guess you get this error when generating code right / reading the model ?
to be able to handle platform./resource uris you have to add following to the workflow
Workflow {
bean = StandaloneSetup {
platformUri = ".."
or when in a Java Context
new StandaloneSetup ().setPlatformUri("..");
MyDemoStandaloneSetup.doSetup();
to get the files read you have to add following to YourDslStandaloneSetup
public void register(Injector injector) {
super.register(injector);
org.eclipse.xtext.resource.IResourceServiceProvider.Registry.INSTANCE.getExtensionToFactoryMap().put("ecore", new EcoreResourceServiceProviderImpl());
and therefore have to add org.eclipse.xtext.ecore to the plugin dependencies.
~Christian
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
[Updated on: Thu, 02 September 2010 06:27] Report message to a moderator
Re: Resolving proxy when processing xtext model [message #556542 is a reply to message #556470] |
Wed, 01 September 2010 16:54 |
Jan Koehnlein Messages: 760 Registered: July 2009 Location: Hamburg |
You are using a platform:/resource URI, which is only valid form within
Eclipse as it refers to projects in the workspace. So it can be linked
in the editor, but not in standalone Java code.
As an alternative, you could use a relative URI or a classpath:/ URI, or
use the URI mapper of your resource set to map the platform:/resource
URI to a file URI.
Jan
Am 01.09.10 15:37, schrieb medo samh:
> The purpose of my grammar is to manipulate a source .ecore model. In my
> grammar, I import Ecore metamodel (http:www.eclipse.org/emf/2002/ecore) to
> type elements of my rules. I also allow importing a source .ecore model,
> using importURI = STRING, where I can supply a URI of a source model that I
> intend to manipulate.
> Below is part of my grammar:
> grammar nha.xtext.demo.MyDemo with org.eclipse.xtext.common.Terminals
> generate myDemo "http://www.xtext.nha/demo/MyDemo"
> import "http://www.eclipse.org/emf/2002/Ecore" as ecore
> Model:
> imports+=Import*
> manipulations+= Manipulations *;
> Import:
> "import" importURI=STRING;
> Manipulations:
> "manipulate" class=[ecore::EClass];
> In the editor, I can type
> import "platform:/resource/projectName/folderName/source.ecore"
> manipulate ClassOne
> // assuming ClassOne is an EClass in model source.ecore which I imported
> This gives me an Xtext file with proxy:
> org.eclipse.emf.ecore.impl.EClassImpl@12b4986 (eProxyURI:
> model/first.mydemo#xtextLink_:://@manipulations.0::http://ww w.xtext.nha/demo/MyDemo«Manipulations«0::/3)
> In my code, I can load the Xtext file successfully but could not resolve the
> proxy to get the name of ClassOne.
> I load the Xtext file using:
> XtextResourceSet drs = new XtextResourceSet();
> URI uri = URI.createURI("folderName/modelName.mydemo");
> Resource xtextResource = drs.getResource(uri , true);
> Model md = (Model) xtextResource.getContents().get(0);
> xtextResource.load(null)
> I try to resolve the proxy using:
> Manipulations manipulations = (Manipulations) manipulations;
> EObject mc = (EObject) manipulations.getClass_();
> if (mc !=null&& mc.eIsProxy()){
> InternalEObject imc =(InternalEObject)mc;
> mc = EcoreUtil.resolve(mc, manipulations);
> This code did not work and I am not sure if this is the right way.
> I am new to xtext and EMF and this problem is stopping me. I would really
> appreciate your advice to go over it.
> Thanks in advance
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Get professional support from the Xtext committers at www.typefox.io
Re: Resolving proxy when processing xtext model [message #556626 is a reply to message #556479] |
Thu, 02 September 2010 07:08 |
Originally posted by: mdsamh.yahoo.com
Hi Christian,
Thanks for your help. I have followed your steps. The two entries in the
Workflow were there by default (did not need to add them). I have added the
register ( ) method to MyDslStandaloneSetup as you suggested.
But now whenever I try to run my program to load my Xtext model, I get the
error below:
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/xtext/ecore/EcoreResourceServiceProviderImplat
nha.xtext.demo.MyDemoStandaloneSetup.register(MyDemoStandalo neSetup.java:24)at
nha.xtext.demo.MyDemoStandaloneSetupGenerated.createInjector AndDoEMFRegistration(MyDemoStandaloneSetupGenerated.java:21) at
nha.xtext.demo.MyDemoStandaloneSetup.doSetup(MyDemoStandalon eSetup.java:18)at
modelDemo.LoadingDemo.load(LoadingDemo.java:24) at
modelDemo.Test_LoadingDemo.main(Test_LoadingDemo.java:48)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.xtext.ecore.EcoreResourceServiceProviderImpl
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 5 more
I am not sure what is the cause of this error. As I said, I new to Xtext
and I could be missing something very obvious.
Thanks in advance for your help
"Christian Dietrich" <christian.dietrich@itemis.de> wrote in message
news:i5lmvs$98s$1@build.eclipse.org...
> the workflow
> Workflow {
> platformUri = "${runtimeProject}/.."
> component = DirectoryCleaner {
> directory = "${runtimeProject}/src-gen"
> @Override
> org.eclipse.xtext.resource.IResourceServiceProvider.Registry .INSTANCE.getExtensionToFactoryMap().put( "ecore",
> dependencies.
> ~Christian
Re: Resolving proxy when processing xtext model [message #556628 is a reply to message #556626] |
Thu, 02 September 2010 07:22 |
Hi did you do that:
btw i am using the eclipse forum and i missed half of your message
in between i updated my post to
Workflow {
platformUri = ".."
(the runtimeProject stuff and dircleaner was just a copy and past error)
and added a solution when not using a workflow:
~Christian
Re: Resolving proxy when processing xtext model [message #556632 is a reply to message #556542] |
Thu, 02 September 2010 07:18 |
Hi Jan,
Thanks for your clarification.
It would be really helpful if you could give some more hints on how to use a
URI mapper of resource set to map a platform URI to a file URI.
Few lines of a sample code would be really great.
Thanks in advance
"Jan K
Re: Resolving proxy when processing xtext model [message #556640 is a reply to message #556632] |
Thu, 02 September 2010 07:45 |
If you start your model reader from a workflow, use the StandaloneSetup
with a platformURI as Christian described above. It maps every file in a
given driectory to a platform URI.
If you're interested in how that works outside a workflow, have a look
at the implementation (the StandaloneSetup class).
Am 02.09.10 09:18, schrieb medo samh:
> Hi Jan,
> Thanks in advance
> "Jan K�oehnlein"<jan.koehnlein@itemis.de> wrote in message
> news:i5m0gn$ejh$1@build.eclipse.org...
>> Eclipse as it refers to projects in the workspace. So it can be linked in
>> use the URI mapper of your resource set to map the platform:/resource URI
>> to a file URI.
>> Regards
>> Jan
>>> Hi,
>>> to
>>> I
>>> Model:
>>> imports+=Import*
>>> Import:
>>> Manipulations:
>>> manipulate ClassOne
>>> the
>>> really
>>> Thanks in advance
FUDForum. Page generated in 0.03570 seconds
