Home » Modeling » TMF (Xtext) » "hidden assignments" in parser rules
"hidden assignments" in parser rules [message #553231] |
Mon, 16 August 2010 17:20 |
Christian Schneider Messages: 23 Registered: July 2009 |
Junior Member |
Dear all,
recently, I realized that the Xtext editor accepts assignments of
concrete values to an attribute of the object the parser rule/rule call
is in charge of. The code generation is working properly, too.
I tested it with an ID, i.e. EString, attribute (the meta model is
imported) like:
CommentAnnotation returns Annotation:
name="comment" value = STRING;
KeyValueAnnotation returns Annotation:
name=ID value= STRING;
However, in the test environment the xtext validator of the concrete
editor complained about no viable input/assignment to the attribute
(here: during CommentAnnotation concerning the name attribute).
Hence, my question is:
What is the current state of that part of Xtext (or did I do something
wrong, maybe)?
cheers,
Christian
Re: "hidden assignments" in parser rules [message #553248 is a reply to message #553231] |
Mon, 16 August 2010 19:31 |
Hello Christian,
can you tell more about the context the rules are used:
i tried following:
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="test"
nsURI="http://www.eclipse.org/test" nsPrefix="test">
<eClassifiers xsi:type="ecore:EClass" name="Model">
<eStructuralFeatures xsi:type="ecore:EReference" name="annotations" upperBound="-1"
eType="#//Annotation" containment="true"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Annotation">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
</ecore:EPackage>
grammar org.xtext.example.mydsl2.MyDsl2 with org.eclipse.xtext.common.Terminals
import "platform:/resource/test/model/test.ecore"
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Model:
annotations+=CommentAnnotation*
annotations+=KeyValueAnnotation*
comment "a"
comment "b"
x "y"
and it works for me
~Christian
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: "hidden assignments" in parser rules [message #553372 is a reply to message #553248] |
Tue, 17 August 2010 09:54 |
Junior Member |
I'm afraid I confused different things!
In this case
"comment" serves as a keyword and is written to name feature
if the rule matches, i.e. "comment" is present (I usually put keywords in single quotes).
What I actually want to achieve is to make the assignment without
mentioning the keyword in the text, like a semantic action in traditional parser generators.
To be in more detail:
In our models we want to declare different sorts of signals:
input, output, inputoutput, local
Our meta model contains a signal class with boolean flags isInput, isOutput.
Thus, I want to write the grammar like
Model:
'input' signals+=InputSignal (',' signals+=InputSignal)*
|'inputoutput' signals+=InputOutputSignal (',' signals+=InputOutputSignal)*
InputSignal returns Signal:
<hidden isInputs=true> name=ID;
InputOutputSignal returns Signal:
<hidden isInputs=true isOutput=true> name=ID;
Would this be possible?
Best,
Christian
On 8/16/10 9:31 PM, Christian Dietrich wrote:
> Hello Christian,
> i tried following:
> upperBound="-1"
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> Model:
> comment "a"
> comment "b"
> x "y"
> and it works for me
> ~Christian
Re: "hidden assignments" in parser rules [message #553692 is a reply to message #553372] |
Wed, 18 August 2010 13:30 |
Henrik Lindberg Messages: 2509 Registered: July 2009 |
You can use something like
Rule : aBooleanAttribute =? 'keyword' ;
To set a boolean if the keyword is present.
- henrik
On 8/17/10 11:54 AM, Christian Schneider wrote:
> In this case
> Model:
> Best,
> Christian
>> Hello Christian,
>> i tried following:
>> <?xml version="1.0" encoding="UTF-8"?>
>> upperBound="-1"
>> </eClassifiers>
>> </eClassifiers>
>> </ecore:EPackage>
>> Model:
>> comment "a"
>> comment "b"
>> x "y"
>> and it works for me
>> ~Christian
Re: "hidden assignments" in parser rules [message #553946 is a reply to message #553692] |
Thu, 19 August 2010 13:39 |
Junior Member |
Of course! :-)
But I want to set a (or more) boolean(s) just by calling a rule, WITHOUT
any keyword consumption!
cheers,
Christian
> - henrik
>> In this case
>> in single quotes).
>> isOutput.
>> Model:
>> Best,
>> Christian
>>> Hello Christian,
>>> i tried following:
>>> upperBound="-1"
>>> </eClassifiers>
>>> </eClassifiers>
>>> </ecore:EPackage>
>>> Model:
>>> comment "a"
>>> comment "b"
>>> x "y"
>>> and it works for me
>>> ~Christian
Re: "hidden assignments" in parser rules [message #554245 is a reply to message #553946] |
Fri, 20 August 2010 17:23 |
As it is not supported to call arbitrary methods from the grammar the
options I come to think of are:
- assign to feature (boolean or other) and modify assignment to have
side effects (as suggested earlier)
- use subclasses that sets the values in question in their constructors
- change the factory that is used by the parser to create model instances
- post processing
- henrik
On 8/19/10 3:39 PM, Christian Schneider wrote:
> Of course! :-)
> cheers,
> Christian
>> - henrik
>>> Hi,
>>> In this case
>>> in single quotes).
>>> isOutput.
>>> Model:
>>> Best,
>>> Christian
>>>> Hello Christian,
>>>> i tried following:
>>>> upperBound="-1"
>>>> </eClassifiers>
>>>> </eClassifiers>
>>>> </ecore:EPackage>
>>>> Model:
>>>> comment "a"
>>>> comment "b"
>>>> x "y"
>>>> and it works for me
>>>> ~Christian
Re: "hidden assignments" in parser rules [message #554601 is a reply to message #554245] |
Mon, 23 August 2010 16:25 |
Junior Member |
That might be a reasonable option on the parsing side.
However, I'm not convinced whether this will work on the serializing
side if the model was constructed outside of Xtext, e.g. programmatically.
For instance: parsing of
input A,B,C
output O
inputoutput P,Q
local L
seems to be easy while serializing such a string seems to be hard to me
if the source is just a list of objects of type 'signal' (with different
boolean attribute settings).
Finally, my question to the Xtext developer is:
Is support of such functionalities on your road map
and, if so, is it for the short or long term?
cheers,
Christian
> - post processing
> Regards
> - henrik
>> Of course! :-)
>> cheers,
>> Christian
>>> - henrik
>>>> Hi,
>>>> In this case
>>>> in single quotes).
>>>> isOutput.
>>>> Model:
>>>> Best,
>>>> Christian
>>>>> Hello Christian,
>>>>> i tried following:
>>>>> name="annotations"
>>>>> upperBound="-1"
>>>>> </eClassifiers>
>>>>> </eClassifiers>
>>>>> </ecore:EPackage>
>>>>> Model:
>>>>> comment "a"
>>>>> comment "b"
>>>>> x "y"
>>>>> and it works for me
>>>>> ~Christian
Current Time: Thu Apr 25 08:44:11 GMT 2024
Powered by FUDForum. Page generated in 0.03253 seconds
