How to check JDT from CVS with dependencies resolved? [message #552676] |
Fri, 13 August 2010 07:21 |
Dear community,
I've read about Team Project Set to import a project with it
dependencies resolved. Is there any Project Set File (PSF) available for
JDT?
If not, could anyone give me an hint about checkin' out from CVS to
create patches?
Thank you,
Chris
Re: How to check JDT from CVS with dependencies resolved? [message #552753 is a reply to message #552684] |
Fri, 13 August 2010 11:21 |
Le 13/08/10 09:44, Daniel Megert a écrit :
> Christophe Bismuth wrote:
>> Dear community,
>> for JDT?
>> create patches?
> You only need to check out the project(s) which you want to patch. PDE
> will resolve the dependencies for you.
> Dani
>> Thank you,
>> Chris
Thank you Dani for your answer. I've downloaded and expanded Eclipse 3.6
SDK on Mac OS X 10.6.4 with Java 6u20 installed. I've also checked out
the org.eclipse.jdt.ui project from CVS. After cleaning and building the
project here are the errors found in the Problems view:
1. API analysis aborted for 'org.eclipse.jdt.ui' since its build path is
incomplete
2. Build path specifies execution environment J2SE-1.4. There are no
JREs installed in the workspace that are strictly compatible with this
environment.
3. The project was not built since its build path is incomplete. Cannot
find the class file for org.eclipse.text.edits.TextEdit. Fix the build
path then try building this project
4. The type org.eclipse.text.edits.TextEdit cannot be resolved. It is
indirectly referenced from required .class files
5. Unsatisfied version constraint: 'org.eclipse.jdt.launching:
[3.6.0,4.0.0)'
6. Unsatisfied version constraint: 'org.eclipse.jface.text: [3.7.0,4.0.0)'
7. Unsatisfied version constraint: 'org.eclipse.ui.workbench.texteditor:
[3.7.0,4.0.0)'
Could you please help me to fix my project setup?
Thank you,
Chris
FUDForum. Page generated in 0.04216 seconds
