Re: no syntax highlighting and no code completion [message #555412 is a reply to message #552521] |
Thu, 26 August 2010 14:21 |
Robin Messages: 25 Registered: August 2010 |
Junior Member |
I have the same problem. I have installed eclipse-SDK-3.6-xtext-1.0.0-win32 and did the Getting Started Guide ( http://www.eclipse.org/Xtext/documentation/latest/xtext.html #getting-started) to the point "Run the Generated IDE Plug-in", where it says:
"Try it a bit and discover the default functionality for code completion ( CTRL SPACE even for cross-references), syntax highlighting, syntactic validation, linking errors, outline, find references etc."
Well, all of that doesn't work. I followed the Getting Started guide word by word. What am I doing wrong?
I checked my Eclipse installation whether or not it has the Antlr feature and it says: Xtext Antlr SDK Feature 1.0.0.v201006151527.
Here's my complete Eclipse configuration:
http://dl.dropbox.com/u/5602365/eclipe-configuration.txt
Please help!
Robin
FUDForum. Page generated in 0.05104 seconds
