Help with using ChangePropertyValueRequest [message #550541] |
Fri, 30 July 2010 14:01 |
I am currently working on a project that requires that I load a diagram and display this diagram into a read-only View. I've accomplished this with a DiagramGraphicalViewer. This part works fine.
My next objective is to programmatically modify certain properties on nodes of this diagram such as line color, line width, etc... I have accomplished this with the code below (as desbribed http://wiki.eclipse.org/GMF_Newsgroup_Q_and_A#How_do_I_chang e_the_color_of_a_line_using_an_action.3F )
@SuppressWarnings("restriction")
public void changeEditPartColor(GraphicalEditPart editPart, Color color) {
ChangePropertyValueRequest req;
req = new ChangePropertyValueRequest(StringStatics.BLANK,
Properties.ID_LINECOLOR, FigureUtilities.colorToInteger(color));
final Command cmd = (Command) editPart.getCommand(req);
AbstractEMFOperation operation = new AbstractEMFOperation(
((IGraphicalEditPart) editPart).getEditingDomain(),
StringStatics.BLANK, null) {
protected IStatus doExecute(IProgressMonitor monitor,
IAdaptable info) {
cmd.execute();
return Status.OK_STATUS;
try {
operation.execute(new NullProgressMonitor(), null);
} catch (org.eclipse.core.commands.ExecutionException e) {
e.printStackTrace();
This also works.
My first question is:
Is this the correct way to do so? I noticed that using org.eclipse.gmf.runtime.diagram.ui.internal.properties.Prope rties gives me a "restriction" warning telling me that Properties is not meant to be accessible. Intuitively it seems as thought I should refrain from using this. Can anyone correct me on why I'm wrong with this. If I do use it, what are the long term implications on the stability of my software (will it's implementation change, etc.)?
My second question is:
Where can I find details on how to set the property values? For example, if I want to create a ChangePropertyValueRequest for Properties.ID_LINE_WIDTH, how do I know at what values to set these? I've tried a few random int values and it doesnt seem to be doing anything. Or should I be using a different technique all together to accomplish these property changes?
Any hints are appreciated,
Charles
FUDForum. Page generated in 0.07898 seconds
