Home » Modeling » GMF (Graphical Modeling Framework) » Selection problem of elements within compartments
Selection problem of elements within compartments [message #550145] Thu, 29 July 2010 09:36 Go to next message
Originally posted by: templth.yahoo.fr
I use two compartments within an element (rectangle one). Everything is
displayed but I can't select elements in compartments in order to resize
or move them. However I can edit and update labels of elements.
Any idea of the cause of the problem? Thanks very much for your help!
Thierry
Re: Selection problem of elements within compartments [message #551373 is a reply to message #550145] Fri, 06 August 2010 08:12 Go to previous messageGo to next message
Kellogs is currently offline KellogsFriend
Hi Thierry,
take a look at the GMF Recipes: http://wiki.eclipse.org/GMF/Recipes
There's a example how to reorder child elements in a compartment, therefore they're selectable.
I'm not sure if you can resize the elements by implementing this example, if it's not possible maybe editing the flow-layout (from the example) can help.
Kellogs
Re: Selection problem of elements within compartments [message #551949 is a reply to message #551373] Tue, 10 August 2010 09:21 Go to previous message
Thanks Kellogs, for the link and the hint. It solved the problem!
Thierry
> Hi Thierry,
> example) can help.
> Kellogs
Previous Topic:how to create a figure without a corresponding model element
Next Topic:Dynamically change connection decoration
Current Time: Thu May 23 13:40:04 GMT 2024
Powered by FUDForum. Page generated in 0.03603 seconds
