Re: Unable to find 'Create project from existing source' while following SWT Example Help document [message #549515 is a reply to message #549392] |
Tue, 27 July 2010 02:38 |
Frank Messages: 23 Registered: July 2010 |
Junior Member |
Eric Rizzo wrote on Mon, 26 July 2010 10:29 | On 7/23/10 2:47 AM, Frank Tao wrote:
> I'm somewhat frustrated.
> I followed the instrument and installed both Eclipse SDK Example and
> Eclipse SDK Example Source. But I really can't find anything even
> simuliar like this:
> eclipse/plugins/org.eclipse.sdk.examples.source_3.1.0/src/or
> g.eclipse.swt.examples_3.1.0
> Can somebody give me a hint? Thanks
It's not clear what you're trying to do or what you're asking. Are you
looking for particular example source code? If so, see here:
http://www.eclipse.org/swt/examples.php
Eric
My question is that this document says that swt example source code is located in eclipse/plugins/org.eclipse.sdk.examples.source_3.1.0/src/or g.eclipse.swt.examples_3.1.0 , but I can't find it. I want to make sure if the document is wrong. If it's right, then what happened in my eclipse installation?
The link given by you is useful, thank you.
[Updated on: Tue, 27 July 2010 02:40] Report message to a moderator
Re: Unable to find 'Create project from existing source' while following SWT Example Help document [message #681838 is a reply to message #677553] |
Thu, 09 June 2011 23:21 |
afry308 Messages: 4 Registered: June 2011 |
Junior Member |
After some digging I was able to resolve this. Here's what I did:
Downloaded "Example Plug-ins" and put extracted files in in dropins/sdkexamples directory. For some reason, I couldn't find SDK examples on the update site.
Next, I created a new empty Java project for SWT examples.
Then I went to File -> Import and imported the archive from dropins/plugins (location of the archive file was the key piece of information I was missing):
eclipse/dropins/sdkexamples/plugins/org.eclipse.swt.examples.source_3.4.0.v3659b.jar
sdkexamples is a directory name that I made up.
Hope this helps some one!
[Updated on: Thu, 09 June 2011 23:22] Report message to a moderator
FUDForum. Page generated in 0.08689 seconds
