Home » Eclipse Projects » Rich Client Platform (RCP) » How to call Java RCP based application from Java Swing( )
How to call Java RCP based application from Java Swing [message #547688] Mon, 19 July 2010 11:18 Go to next message
No real name is currently offline No real nameFriend
I need to call RCP application from a command or menu of Java Swing application. Is it feasible?. I have explored SWT_AWT bridge, through which Spring application can be converted to RCP. This scenario is not feasible for me as my Swing application is extremely complex and i don't want to change it entirely into RCP. I just need to call RCP application from Java Swing
Nidhi
Re: How to call Java RCP based application from Java Swing [message #547693 is a reply to message #547688] Mon, 19 July 2010 11:21 Go to previous messageGo to next message
Daniel Krügler is currently offline Daniel KrüglerFriend
> from Java Swing
I'm not sure what you mean. If you start an application from another
application, this is like starting a new process from another process -
in which way should you be required to use the SWT_AWT bridge?
HTH & Greetings from Bemen,
Daniel Krügler
Re: How to call Java RCP based application from Java Swing [message #547707 is a reply to message #547693] Mon, 19 July 2010 12:13 Go to previous messageGo to next message
I need to start RCP application from Java Swing application.
Appreciate , if you could provide any insight on this aspect.
Thnx
Nidhi
Re: How to call Java RCP based application from Java Swing [message #547749 is a reply to message #547688] Mon, 19 July 2010 14:18 Go to previous message
Paul Webster is currently offline Paul WebsterFriend
See
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/misc/eclipsestarter.html
That discusses how to start an eclipse-based java app from within
another java app (which may or may not be swing based :-)
PW
Paul Webster
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Problem with setting the classpath
Next Topic:RCP client for EJB, cannot lookup.
Current Time: Tue Sep 27 08:08:05 GMT 2022
Powered by FUDForum. Page generated in 0.04378 seconds
