Subreport needed? [message #545970] |
Fri, 09 July 2010 18:06 |
Originally posted by: pschoenb.gmx.de
I want to display the following data structure:
Each data element has a header and 0..n subentries within a two-column
table. My data comes from a scripted datasource.
I am wondering how to implement this. Do I need a subreport for the
subentry table mentioned above?
Patrick
email: pschoenb@gmx.de
PGP public key available. Key ID: 0B7DDE39
Or email to pgp@robustsoft.de with subject 'pschoenb'.
Fingerprint: BE80 0E7E B68E CE99 623C 902D 62A6 806A 0B7D DE39
Re: Subreport needed? [message #545984 is a reply to message #545970] |
Fri, 09 July 2010 19:23 |
If your scripted data is bringing in everything you need, probably not.
Assuming you have a query returning a row like:
[header field 1][header field 2][header field n][detail field 1][detail field 2][detail field n]
You can pull that into a table in BIRT, then within the table group on one or more of your header fields. Then you can show header information in the header row, and detail information in the detail rows.
Re: Subreport needed? [message #546080 is a reply to message #545984] |
Sat, 10 July 2010 19:07 |
But if I get it right, the Java event handler is called once for each
row, right? So, if the handler is called once for each header, how do I
fill in the detail rows?
Patrick
Re: Subreport needed? [message #546098 is a reply to message #545970] |
Sat, 10 July 2010 23:41 |
I think you're confusing two different loci of action.
The DataSet object uses the scripted datasource to generate a set/stream of DataSetRow elements.
The Table object then takes the set of DataSetRow elements and interprets them, in this case creating a header group and doing layout. The Table object has no connection with the DataSource; it merely consumes and processes the output of the DataSet.
One of the BIRT specialists can probably correct me if any of the above is in error.
FUDForum. Page generated in 0.01855 seconds
