Re: Add a scroll bar to a parameter list when executing a report [message #545894 is a reply to message #545535] |
Fri, 09 July 2010 14:29 |
Adriana,
The code that is used to create the drop down is located in the
viewer(plugin in designer/or deployed viewer). You can look at it in
Deployed App
ExampleWebViewer\webcontent\birt\pages\parameter
in Designer
eclipse\plugins\org.eclipse.birt.report.viewer_2.6.0.v201006 05\birt\webcontent\birt\pages\parameter
The file is ComboBoxParameterFragment.jsp. It contains a select tag
with all the options. I do not think select tag supports a horizontal
scroll bar, but you may be able to modify the size of the box. You can
also look at the style that is used (birtviewer_parameter_dialog_Select)
in the style.css file located in the
webcontent\birt\styles directory.
Jason
On 7/8/2010 4:18 AM, anitescu@gmail.com wrote:
> Hello,
> For my report I have a parameter which maps some element description.
> This description sometimes has more than 20 characters and it is
> difficult to see it in the parameter selection list.
> There is a way I can configure this list to add a scroll bar and to
> specify a higher size?
> Thanks for your help
> Adriana
FUDForum. Page generated in 0.01266 seconds
