Re: Font sizes larger in 2.6 than in 2.3? [message #545884 is a reply to message #545514] |
Fri, 09 July 2010 14:15 |
Can you open a bug for this? You could also create a css sheet with the
defaults you want and import them into the reports.
Jason
On 7/8/2010 2:48 AM, Juergen Schwarz wrote:
> Found the cause:
> In method getMediumFontSize() of class
> org.eclipse.birt.report.engine.css.engine.BIRTCSSEngine the default
> medium font size had been changed from 9pt to 12pt. I suppose there is
> no other way to get the old sizes other than changing it back to 9 in
> the source?
> Am 08.07.2010 08:03, schrieb Juergen Schwarz:
>> We're just switching from BIRT 2.3 to 2.6 and noticed that all texts in
>> PDF output come out much larger in 2.6 than they were in 2.3.
FUDForum. Page generated in 0.02713 seconds
