BIRT viewer doesn't work with VPN [message #545364] |
Wed, 07 July 2010 14:22 |
B Boose Messages: 7 Registered: July 2010 |
Junior Member |
I'm using BIRT 2.3.2 with jboss 5.1 as a deployed war
When I access a report directly:
servername.com/reports/frameset?__report=org_chart_district.rptdesign&__toolbar=false
(this is the normal mode of operation) everything works fine. But when I access it using vpn:
vpn_alias.com/reports/frameset?__report=org_chart_district.rptdesign&__toolbar=false
I get the report template, but nothing else. If I change it so that I'm not using the viewer:
alias.com/reports/run?__report=org_chart_district.rptdesign&__format=pdf
I get the report(so it's hitting the database), but now I don't have any of the features of the viewer. Is there some configuration setting I'm missing for this?
This is my first experience with BIRT, I'd appreciate any advice.
[Updated on: Wed, 07 July 2010 14:22] Report message to a moderator
Re: BIRT viewer doesn't work with VPN [message #545407 is a reply to message #545364] |
Wed, 07 July 2010 16:25 |
Any chance you can try the 2.6.0 viewer?
Jason
> servername.com/reports/frameset?__report=org_chart_district. rptdesign&__toolbar=false
> vpn_alias.com/reports/frameset?__report=org_chart_district.r ptdesign&__toolbar=false
> alias.com/reports/run?__report=org_chart_district.rptdesign& amp;__format=pdf
> missing for this?
Re: BIRT viewer doesn't work with VPN [message #545906 is a reply to message #545742] |
Fri, 09 July 2010 14:56 |
I suspect since you can run the /run mapping and not the /frameset
mapping this has something to do with the AJAX code making web service
calls to the viewer. Can you open a bugzilla entry so the dev team can
help diagnose. Do you have anything in the log file?
Jason
On 7/8/2010 4:41 PM, gebuh@aol.com wrote:
> if I can come up with a strong enough argument, thing is, because this
> is using vpn, the only way to test it is to go live with it. Are there
> changes in 2.6.0 that might account for this problem?
> Jason Weathersby wrote on Wed, 07 July 2010 12:25
>> Jason
FUDForum. Page generated in 0.02773 seconds
