Re: hiding table rows depending on other table [message #545084 is a reply to message #544615] |
Tue, 06 July 2010 14:51 |
Milan,
Take a look at the attached example. In the beforeFactory it sets a
global variable that is used in the visibility expression of the second
nested table. By default the second table will not be displayed. There
is a script on the first inner table's row oncreate that changes the
global variable to show the second table. Run the report with the
default parameter to see both tables. Change the parameter to 1 to see
the second table disappear.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.5.2.v20100208 Build <2.5.2.v20100210-0630></property>
<property name="units">in</property>
<method
name="beforeFactory"><![CDATA[importPackage(Packages.java.lang);
reportContext.setGlobalVariable("ShowTableTwo", new Integer(0));]]></method>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<parameters>
<scalar-parameter name="ds1query" id="111">
<property name="valueType">static</property>
<property name="dataType">integer</property>
<property name="distinct">true</property>
<simple-property-list name="defaultValue">
<value type="constant">10101</value>
</simple-property-list>
<property name="paramType">simple</property>
<property name="controlType">text-box</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="OuterTable" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">PRODUCTLINE</property>
<text-property
name="displayName">PRODUCTLINE</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">PRODUCTLINE</property>
<property name="dataType">string</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">PRODUCTLINE</property>
<property name="nativeDataType">12</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select productline
from productlines
where productline like '%Tra%']]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTLINE</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>PRODUCTLINE</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>PRODUCTLINE</design:label>
<design:formattingHints>
<design:displaySize>50</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>TEXTDESCRIPTION</design:name>
<design:position>2</design:position>
<design:precision>4000</design:precision>
<design:uiHints>
<design:displayName>TEXTDESCRIPTION</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>TEXTDESCRIPTION</design:label>
<design:displaySize>4000</design:displaySize>
<design:attributes>
<design:name>HTMLDESCRIPTION</design:name>
<design:position>3</design:position>
<design:nativeDataTypeCode>2005</design:nativeDataTypeCode >
<design:precision>2147483647</design:precision>
<design:uiHints>
<design:displayName>HTMLDESCRIPTION</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>HTMLDESCRIPTION</design:label>
<design:displaySize>2147483647</design:displaySize>
<design:attributes>
<design:name>IMAGE</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>2004</design:nativeDataTypeCode >
<design:uiHints>
<design:displayName>IMAGE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>IMAGE</design:label>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set
name="InnerDS1" id="37">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<list-property name="parameters">
<structure>
<property name="name">param_1</property>
<property name="paramName">ds1query</property>
<property name="nativeName"></property>
<property name="nativeDataType">4</property>
<property name="isOptional">true</property>
<property name="allowNull">true</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<structure>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">ORDERNUMBER</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails
where ordernumber = ?]]></xml-property>
<model:DesignValues
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:inputAttributes>
<design:elementAttributes>
<design:optional>true</design:optional>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
</design:DataSetParameters>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:displaySize>11</design:displaySize>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
<design:criteria/>
</oda-data-set>
<oda-data-set
name="InnerDS2" id="38">
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
from orderdetails
where ordernumber = 10104]]></xml-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="dataSet">OuterTable</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression name="expression"
type="javascript">dataSetRow["PRODUCTLINE"]</expression >
</structure>
</list-property>
<column id="33"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property
name="text">PRODUCTLINE</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="19">
<cell id="20">
<data id="21">
<property
name="resultSetColumn">PRODUCTLINE</property>
</data>
</cell>
</row>
<row id="39">
<cell id="40">
<table id="43">
<property
name="backgroundColor">#8080C0</property>
<property name="dataSet">InnerDS1</property>
<structure>
<property
<text-property
type="javascript">dataSetRow["ORDERNUMBER"]</expression >
<property
</structure>
<structure>
<property
<text-property
type="javascript">dataSetRow["PRODUCTCODE"]</expression >
<property
</structure>
<structure>
<property
<text-property
type="javascript">dataSetRow["QUANTITYORDERED"]</expression >
<property
</structure>
<structure>
<property
<text-property
type="javascript">dataSetRow["PRICEEACH"]</expression>
<property
</structure>
<structure>
<property
<text-property
type="javascript">dataSetRow["ORDERLINENUMBER"]</expression >
<property
</structure>
</list-property>
<column id="72"/>
<column id="73"/>
<column id="74"/>
<column id="75"/>
<column id="76"/>
<header>
<row id="44">
<cell id="45">
<label id="46">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="47">
<label id="48">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="49">
<label id="50">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="51">
<label id="52">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="53">
<label id="54">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="55">
<method
name="onCreate"><![CDATA[importPackage(Packages.java.lang);
reportContext.setGlobalVariable("ShowTableTwo", new Integer(1));]]></method>
<cell id="56">
<data id="57">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="58">
<data id="59">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="60">
<data id="61">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="62">
<data id="63">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="64">
<data id="65">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="66">
<cell id="67"/>
<cell id="68"/>
<cell id="69"/>
<cell id="70"/>
<cell id="71"/>
</row>
</footer>
</table>
</cell>
</row>
<row id="41">
<cell id="42">
<table id="77">
<property
name="backgroundColor">#FF8080</property>
<property name="dataSet">InnerDS2</property>
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr"
type="javascript">importPackage(Packages.java.lang);
var vis =reportContext.getGlobalVariable("ShowTableTwo");
if( vis > 0 ){
false;
}else{
true;
}</expression>
</structure>
</list-property>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
</list-property>
<column id="106"/>
<column id="107"/>
<column id="108"/>
<column id="109"/>
<column id="110"/>
<header>
<row id="78">
<cell id="79">
<label id="80">
<text-property
</label>
</cell>
<cell id="81">
<label id="82">
<text-property
</label>
</cell>
<cell id="83">
<label id="84">
<text-property
</label>
</cell>
<cell id="85">
<label id="86">
<text-property
</label>
</cell>
<cell id="87">
<label id="88">
<text-property
</label>
</cell>
</row>
</header>
<detail>
<row id="89">
<cell id="90">
<data id="91">
<property
</data>
</cell>
<cell id="92">
<data id="93">
<property
</data>
</cell>
<cell id="94">
<data id="95">
<property
</data>
</cell>
<cell id="96">
<data id="97">
<property
name="resultSe
FUDForum. Page generated in 0.03006 seconds
