Re: strange error: driver? [message #541846 is a reply to message #541817] |
Tue, 22 June 2010 17:11 |
Do all postgresql reports fail or just some?
Jason
On 6/22/2010 11:41 AM, nicola wrote:
> my application has several reports and I use birt-viewer 2.5.2 to
> display them.
> My problem is that I get this error with some of them:
> 2010-06-22 17:34:09,147 ERROR [STDERR] 22-giu-2010 17.34.09
> org.eclipse.birt.report.engine.api.impl.RunTask doRun
> GRAVE: Error happened while running the report.
> java.lang.NoClassDefFoundError: org/postgresql/util/GT
> at
> org.postgresql.jdbc2.AbstractJdbc2ResultSet.toInt(AbstractJd bc2ResultSet.java:2699)
> at
> org.postgresql.jdbc2.AbstractJdbc2ResultSet.getInt(AbstractJ dbc2ResultSet.java:2016)
> at
> org.eclipse.birt.report.data.oda.jdbc.ResultSet.getInt(Resul tSet.java:250)
> at
> org.eclipse.datatools.connectivity.oda.consumer.helper.OdaRe sultSet.getInt(OdaResultSet.java:312)
> at
> org.eclipse.birt.data.engine.odaconsumer.ResultSet.getInt(Re sultSet.java:227)
> at
> org.eclipse.birt.data.engine.odaconsumer.ResultSet.fetch(Res ultSet.java:169)
> at
> org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch (OdiAdapter.java:153)
> at
> org.eclipse.birt.data.engine.executor.cache.RowResultSet.nex t(RowResultSet.java:105)
> at
> org.eclipse.birt.data.engine.executor.cache.ExpandableRowRes ultSet.next(ExpandableRowResultSet.java:63)
> at
> org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .populateData(SmartCacheHelper.java:311)
> at
> org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .initInstance(SmartCacheHelper.java:283)
> at
> org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .initOdaResult(SmartCacheHelper.java:152)
> at
> org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .getResultSetCache(SmartCacheHelper.java:77)
> at
> org.eclipse.birt.data.engine.executor.cache.SmartCache.<init >(SmartCache.java:53)
> at
> org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.populateOdiResultSet(PassUtil.java:99)
> at
> org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.pass(PassUtil.java:62)
> at
> org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.populateResultSetCacheInResultSetPopulator(PassManager. java:340)
> at
> org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.doPopulation(PassManager.java:294)
> at
> org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.doMultiPass(PassManager.java:230)
> at
> org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.pass(PassManager.java:97)
> at
> org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.populateResultSet(PassManager.java:74)
> at
> org.eclipse.birt.data.engine.executor.transform.ResultSetPop ulator.populateResultSet(ResultSetPopulator.java:196)
> at
> org.eclipse.birt.data.engine.executor.transform.CachedResult Set. <init>(CachedResultSet.java:90)
> at
> org.eclipse.birt.data.engine.executor.DataSourceQuery.execut e(DataSourceQuery.java:848)
> at
> org.eclipse.birt.data.engine.impl.PreparedOdaDSQuery$OdaDSQu eryExecutor.executeOdiQuery(PreparedOdaDSQuery.java:399)
> at
> org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:1045)
> at
> org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:232)
> at
> org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:158)
> at
> org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init >(QueryResultSet.java:98)
> at
> org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:168)
> at
> org.eclipse.birt.report.engine.data.dte.DataGenerationEngine .doExecuteQuery(DataGenerationEngine.java:74)
> at
> org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:265)
> at
> org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1875)
> at
> org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:80)
> at
> org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:62)
> at
> org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute(WrappedReportItemExecutor.java:4 6)
> at
> org.eclipse.birt.report.engine.internal.executor.emitter.Rep ortItemEmitterExecutor.execute(ReportItemEmitterExecutor.jav a:46)
> at
> org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:65)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la youtChildren(HTMLStackingLM.java:26)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:140)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.resumeLayout(HTMLInlineStackingLM.java:111)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.layoutNodes(HTMLInlineStackingLM.java:160)
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:70)
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou tChildren(HTMLTableLM.java:132)
> at
> at
> at
> org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
> at
> org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
> at
> org.eclipse.birt.report.engine.presentation.ReportDocumentBu ilder.build(ReportDocumentBuilder.java:258)
> at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:252)
> at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:85)
> at
> org.eclipse.birt.report.service.ReportEngineService.runRepor t(ReportEngineService.java:1307)
> at
> org.eclipse.birt.report.service.BirtViewerReportService.runR eport(BirtViewerReportService.java:158)
> at
> org.eclipse.birt.report.service.actionhandler.BirtRunReportA ctionHandler.__execute(BirtRunReportActionHandler.java:81)
> at
> org.eclipse.birt.report.service.actionhandler.BirtGetPageAct ionHandler.__checkDocumentExists(BirtGetPageActionHandler.ja va:58)
> at
> org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.prepareParameters(AbstractGetPageActionHandle r.java:119)
> at
> org.eclipse.birt.report.service.actionhandler.AbstractGetPag eActionHandler.__execute(AbstractGetPageActionHandler.java:1 04)
> at
> org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:90)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction(AbstractBaseComponentProcessor .java:143)
> at
> org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPage(BirtDocumentProcessor.java:87)
> at sun.reflect.GeneratedMethodAccessor1505.invoke(Unknown Source)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(AbstractBaseComponentProcessor.java: 112)
> at
> org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(BirtSoapBindingImpl.java:66)
> at sun.reflect.GeneratedMethodAccessor565.invoke(Unknown Source)
> at
> at
> org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397)
> at
> org.apache.axis.providers.java.RPCProvider.processMessage(RP CProvider.java:186)
> at
> org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323)
> at
> org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32)
> at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
> at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
> at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454)
> at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281
> 2010-06-22 17:34:09,147 ERROR [STDERR] )
> at org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(BirtSoapMessageDispatcherServlet.java:265)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
> at
> org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
> at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
> at
> org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:122)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
> at
> org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
> at
> org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF ilter.java:68)
> at
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235)
> at
> at
> org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(Repl yHeaderFilter.java:96)
> at
> at
> at
> org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:230)
> at
> org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:175)
> at
> org.jboss.web.tomcat.security.SecurityAssociationValve.invok e(SecurityAssociationValve.java:182)
> at
> org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccCo ntextValve.java:84)
> at
> org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
> at
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
> at
> org.jboss.web.tomcat.service.jca.CachedConnectionValve.invok e(CachedConnectionValve.java:157)
> at
> org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
> at
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:262)
> at
> org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:844)
> at
> org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:583)
> at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:446)
> at java.lang.Thread.run(Thread.java:619)
> 2010-06-22 17:34:09,227 ERROR [STDERR]
> org.eclipse.birt.data.engine.core.DataException: A report document error
> occurred when getting the save stream.
> Can not create entry named /DataEngine/NamingRelationbecause the archive
> file has been closed. System ID: null
> Could it be a JDBC problem? I user postgres with
> postgresql-8.3-603.jdbc4.jar.
> Any suggestions to investigate the problem, please?
> Thank you,
> Nicola
FUDForum. Page generated in 0.04870 seconds
