Re: Stack Overflow deploying Birt on Websphere 6.1 with Java2 Security [message #539332 is a reply to message #538878] |
Thu, 10 June 2010 13:03 |
Here is a note on this issue from Jun Ouyang on the development team:
In Websphere you can fix the problem as follows:
1. add configuration in config.ini:
eclipse.security=true
2. add permissions for BIRT:
Edit file install_root/config/cells/cell_name/applications/
ear_file_name/deployments/application_name(birt)/META-INF/wa s.policy,
add permission:
grant codeBase "file:birt.war" {
permission java.security.AllPermission;
Please notice "birt.war" above is same as the .war folder in the deploy
folder.
On 6/8/2010 5:14 PM, mcastoe wrote:
> Our application has an embedded version of Birt 2.5.0 and we are trying
> to deploy on a Websphere 6.1 server with Java2 security enabled. We have
> followed the instructions found in bugzilla 182161,
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=182161, but the OSGi layer
> will not startup. The eclipse/osgi error log shows a very deep recursive
> stack trace with an eventual stackOverflow exception. The last couple
> iterations and the exception are show below.
> Has anybody out there had any experience with this? We do find that
> people have had trouble with Birt on Websphere + java2 security but no
> clear resolutions for what to do. We have granted
> java.security.AllPermision but it is after that settgin atht we begin to
> see this error as osgi tries to process the security permissions for the
> eclipse bundles.
> Any help appreciated...
> Partial Stack trace:
> Caused by: java.lang.StackOverflowError
> at org.osgi.framework.AdminPermission.getProperties(AdminPermis
> sion.java:826)
> at org.osgi.framework.AdminPermission.implies0(AdminPermission. java:650)
> at org.osgi.framework.AdminPermissionCollection.implies(AdminPe
> rmission.java:962)
> at org.eclipse.osgi.framework.internal.core.ConditionalPermissi
> onSet.implies(ConditionalPermissionSet.java:224)
> at org.eclipse.osgi.framework.internal.core.BundleCombinedPermi
> ssions.implies(BundleCombinedPermissions.java:124)
> at java.security.ProtectionDomain.implies(ProtectionDomain.java :225)
> at java.security.AccessController.checkPermission(AccessControl
> ler.java:94)
> at java.lang.SecurityManager.checkPermission(SecurityManager.ja va:547)
> at com.ibm.ws.security.core.SecurityManager.checkPermission(Sec
> urityManager.java:212)
> at org.eclipse.osgi.framework.internal.core.Framework.checkAdmi
> nPermission(Framework.java:1178)
> at org.eclipse.osgi.framework.internal.core.AbstractBundle.getL
> ocation(AbstractBundle.java:997)
> at org.osgi.framework.AdminPermission$1.run(AdminPermission.jav a:830)
> at java.security.AccessController.doPrivileged(AccessController .java:192)
> sion.java:827)
> rmission.java:962)
> ler.java:94)
> sion.java:827)
> rmission.java:962)
FUDForum. Page generated in 0.02043 seconds
