sql query text for a new data set [message #537252] |
Tue, 01 June 2010 16:50 |
Hesus Messages: 1 Registered: June 2010 |
Junior Member |
Hello all,
First of all thank you for all the information stored here which helps all of us to learn BIRT and be able to develop all the objects needed for our jobs, courses, etc...
I need your help...
I need to know how I can to join several queries into a unique new data set sql query text. For example, with Reporting Services I able to specify several queries in a unique data set and use it to show data in my report, I don't know if I explain it correctly. I need to do the following steps:
drop table <schema_name>."<table_name>";
create table <schema_name>."<table_name>"
as
select distinct "<column_name>", count(*) as "<alias_name>"
from <schema_name>."<another_table>"
group by "<another_column>";
select <alias_1>."<column>", <alias_1>."<column>", <alias_1>."column", <alias_2>."column"
from <schema_name>."<another_table>" <alias_1>, <schema_name>."<another_table>" <alias_2>
where ...;
I mean, I need three (or several) queries in my data set sql query text in order to build the data set which I'll use to show it in the report.
Please, could you help me about this? It's possible to do that? I hope my explanation have been clear. Sorry for my English level...
Thanks in advance.
Best regards...
Re: sql query text for a new data set [message #537260 is a reply to message #537252] |
Tue, 01 June 2010 17:37 |
I don't think you can execute DDL in the Dataset query, at least I cannot using Oracle. Why do you need to have your BIRT report create a permanent database table? With what you have described I would think you could write a single query referencing all necessary tables and creating aliases. What database are you using?
FUDForum. Page generated in 0.02954 seconds
