Home » Archived » BIRT » How to control pagebreak on PDF report (How to control pagebreak on PDF report in nested table)
How to control pagebreak on PDF report [message #534295] Tue, 18 May 2010 15:19 Go to next message
Amy  is currently offline Amy Friend
I need to create a PDF report, the report has 2 nested tables -> A and B.
Table A is outer table with table header and a grid to hold data for table A. Inside detail, I need to add a inner table B to display data set.
The table A header only need show one time. So, I unchecked the "repeat header " box. The problem is : once I uncheck the "repeat header " box, if the table B has more records back ( > 16 records), the table B go to next page display data. The first page only see the table A (outer table ) header. How I can control the nested table, let the innert table show data below the outer table header even the table B ( inner table ) has more records back?
I created a simple report using the BIRT simple database to show the problem. ( In my real report, table A and table B linked together. For this simple, the 2 tables are not linked. I just want to create the report with more data sets in inner table )
Here is the code:
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.21" id="1">
<property name="comments">Copyright (c) 2006 &lt;&lt;Your Company
Name here>></property>
<property name="createdBy">Eclipse BIRT Designer Version 2.5.2.v20100208 Build &lt;2.5.2.v20100210-0630></property>
<property name="units">in</property>
<method name="beforeFactory"><![CDATA[myArray = [];
ctr=0;
rctr=0;]]></method>
<property name="layoutPreference">auto layout</property>
<data-sources>
<script-data-source name="Data Source" id="4"/>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source1" id="85">
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Customers" id="86">
<list-property name="columnHints">
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property name="displayName">CUSTOMERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNAME</property>
<text-property name="displayName">CUSTOMERNAME</text-property>
</structure>
<structure>
<property name="columnName">CONTACTLASTNAME</property>
<text-property name="displayName">CONTACTLASTNAME</text-property>
</structure>
<structure>
<property name="columnName">CONTACTFIRSTNAME</property>
<text-property name="displayName">CONTACTFIRSTNAME</text-property>
</structure>
<structure>
<property name="columnName">PHONE</property>
<text-property name="displayName">PHONE</text-property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE1</property>
<text-property name="displayName">ADDRESSLINE1</text-property>
</structure>
<structure>
<property name="columnName">ADDRESSLINE2</property>
<text-property name="displayName">ADDRESSLINE2</text-property>
</structure>
<structure>
<property name="columnName">CITY</property>
<text-property name="displayName">CITY</text-property>
</structure>
<structure>
<property name="columnName">STATE</property>
<text-property name="displayName">STATE</text-property>
</structure>
<structure>
<property name="columnName">POSTALCODE</property>
<text-property name="displayName">POSTALCODE</text-property>
</structure>
<structure>
<property name="columnName">COUNTRY</property>
<text-property name="displayName">COUNTRY</text-property>
</structure>
<structure>
<property name="columnName">SALESREPEMPLOYEENUMBER</property>
<text-property name="displayName">SALESREPEMPLOYEENUMBER</text-property>
</structure>
<structure>
<property name="columnName">CREDITLIMIT</property>
<text-property name="displayName">CREDITLIMIT</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">CUSTOMERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">CUSTOMERNAME</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">PHONE</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">ADDRESSLINE1</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">ADDRESSLINE2</property>
</structure>
<structure>
<property name="position">8</property>
<property name="name">CITY</property>
</structure>
<structure>
<property name="position">9</property>
<property name="name">STATE</property>
</structure>
<structure>
<property name="position">10</property>
<property name="name">POSTALCODE</property>
</structure>
<structure>
<property name="position">11</property>
<property name="name">COUNTRY</property>
</structure>
<structure>
<property name="position">12</property>
<property name="name">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="position">13</property>
<property name="name">CREDITLIMIT</property>
<property name="dataType">float</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source1</property>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNAME</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">CONTACTLASTNAME</property>
</structure>
<structure>
<property name="nativeName">CONTACTFIRSTNAME</property>
</structure>
<structure>
<property name="nativeName">PHONE</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE1</property>
</structure>
<structure>
<property name="nativeName">ADDRESSLINE2</property>
</structure>
<structure>
<property name="nativeName">CITY</property>
</structure>
<structure>
<property name="nativeName">STATE</property>
</structure>
<structure>
<property name="nativeName">POSTALCODE</property>
</structure>
<structure>
<property name="nativeName">COUNTRY</property>
</structure>
<structure>
<property name="nativeName">SALESREPEMPLOYEENUMBER</property>
</structure>
<structure>
<property name="nativeName">CREDITLIMIT</property>
<property name="nativeDataType">8</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from CLASSICMODELS.CUSTOMERS
--where CLASSICMODELS.CUSTOMERS.CUSTOMERNUMBER=?]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml version="1.0" encoding="UTF-8"?>
<model:DesignValues xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design" xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>CUSTOMERNAME</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>50</design:precision>
<design:uiHints>
<design:displayName>CUSTOMERNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNAME</design:label>
<design:displaySize>50</design:displaySize>
<design:attributes>
<design:name>CONTACTLASTNAME</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>CONTACTLASTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTLASTNAME</design:label>
<design:attributes>
<design:name>CONTACTFIRSTNAME</design:name>
<design:position>4</design:position>
<design:uiHints>
<design:displayName>CONTACTFIRSTNAME</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CONTACTFIRSTNAME</design:label>
<design:attributes>
<design:name>PHONE</design:name>
<design:position>5</design:position>
<design:uiHints>
<design:displayName>PHONE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PHONE</design:label>
<design:attributes>
<design:name>ADDRESSLINE1</design:name>
<design:position>6</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE1</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE1</design:label>
<design:attributes>
<design:name>ADDRESSLINE2</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>ADDRESSLINE2</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ADDRESSLINE2</design:label>
<design:attributes>
<design:name>CITY</design:name>
<design:position>8</design:position>
<design:uiHints>
<design:displayName>CITY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CITY</design:label>
<design:attributes>
<design:name>STATE</design:name>
<design:position>9</design:position>
<design:uiHints>
<design:displayName>STATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATE</design:label>
<design:attributes>
<design:name>POSTALCODE</design:name>
<design:position>10</design:position>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>POSTALCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>POSTALCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>COUNTRY</design:name>
<design:position>11</design:position>
<design:uiHints>
<design:displayName>COUNTRY</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COUNTRY</design:label>
<design:attributes>
<design:name>SALESREPEMPLOYEENUMBER</design:name>
<design:position>12</design:position>
<design:uiHints>
<design:displayName>SALESREPEMPLOYEENUMBER</design:displayName >
</design:uiHints>
<design:usageHints>
<design:label>SALESREPEMPLOYEENUMBER</design:label>
<design:attributes>
<design:name>CREDITLIMIT</design:name>
<design:position>13</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>CREDITLIMIT</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CREDITLIMIT</design:label>
<design:displaySize>22</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Payment" id="87">
<structure>
</structure>
<structure>
<property name="columnName">CHECKNUMBER</property>
<text-property name="displayName">CHECKNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PAYMENTDATE</property>
<text-property name="displayName">PAYMENTDATE</text-property>
</structure>
<structure>
<property name="columnName">AMOUNT</property>
<text-property name="displayName">AMOUNT</text-property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="name">CHECKNUMBER</property>
</structure>
<structure>
<property name="name">PAYMENTDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="name">AMOUNT</property>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
<property name="nativeName">CHECKNUMBER</property>
</structure>
<structure>
<property name="nativeName">PAYMENTDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">AMOUNT</property>
</structure>
</list-property>
from CLASSICMODELS.PAYMENTS]]></xml-property>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:name>CHECKNUMBER</design:name>
<design:uiHints>
<design:displayName>CHECKNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CHECKNUMBER</design:label>
<design:attributes>
<design:name>PAYMENTDATE</design:name>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PAYMENTDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PAYMENTDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>AMOUNT</design:name>
<design:uiHints>
<design:displayName>AMOUNT</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>AMOUNT</design:label>
<design:criteria/>
</oda-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="Orders" id="264">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property name="displayName">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property name="displayName">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property name="displayName">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property name="displayName">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<text-property name="displayName">STATUS</text-property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<text-property name="displayName">COMMENTS</text-property>
</structure>
<structure>
</structure>
</list-property>
<structure>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="name">ORDERDATE</property>
</structure>
<structure>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="name">STATUS</property>
</structure>
<structure>
<property name="name">COMMENTS</property>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
<property name="nativeName">ORDERNUMBER</property>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
</structure>
</list-property>
from CLASSICMODELS.ORDERS
--where CLASSICMODELS.ORDERS.CUSTOMERNUMBER= ?]]></xml-property>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>STATUS</design:name>
<design:uiHints>
<design:displayName>STATUS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATUS</design:label>
<design:attributes>
<design:name>COMMENTS</design:name>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>COMMENTS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COMMENTS</design:label>
<design:displaySize>32700</design:displaySize>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
</oda-data-set>
</data-sets>
<styles>
<style name="table-header" id="37">
<property name="backgroundColor">#6078BF</property>
<property name="fontFamily">"Arial"</property>
Re: How to control pagebreak on PDF report [message #534299 is a reply to message #534295] Tue, 18 May 2010 15:25 Go to previous messageGo to next message
Richard A. Polunsky is currently offline Richard A. PolunskyFriend
I'm going to paraphrase your description as i don't have bandwidth to test the report:
Outer Table A has a header row with "repeat header" unchecked.
When Inner Table B has more than 16 records, its contents force a page break and don't start until Page 2, so Page 1 shows Table A header only and Page 2 shows Table B contents.
It sounds like somewhere in your Inner Table B, either at the table level or the group level, you have page break inner set to Avoid. (This could also be coming from the row in Outer Table A where you have embedded Inner Table B). Change that break setting from Avoid to Auto and you might resolve your issue.
Re: How to control pagebreak on PDF report [message #534314 is a reply to message #534299] Tue, 18 May 2010 15:48 Go to previous messageGo to next message
Richard,
I checked my code, no any place I set the page break as Avoid.
I search XML code and back to layout view, check each table, grid and row.
Any other suggestion?
Thanks!
Amy
[Updated on: Tue, 18 May 2010 15:49]
Report message to a moderator
Re: How to control pagebreak on PDF report [message #534316 is a reply to message #534295] Tue, 18 May 2010 15:56 Go to previous messageGo to next message
The report as posted above is incomplete.
Please email me a copy direct at rpolunsky@yahoo.com and I'll look at it.
Re: How to control pagebreak on PDF report [message #534348 is a reply to message #534316] Tue, 18 May 2010 18:44 Go to previous messageGo to next message
Richard,
I send the code to your account.
Please check.
Thanks!
Amy
Re: How to control pagebreak on PDF report [message #534351 is a reply to message #534295] Tue, 18 May 2010 19:19 Go to previous messageGo to next message
First, you have not put any kind of filter or binding linking the inner table to the outer table. therefore, every single row in your outer table is going to show ALL of the data from your inner table query. I suspect what you intended was to link the two, where inner table customer number = outer table customer number.
That said, I can replicate the behavior when I select PDF as the output format, and in the web viewer (which takes forever to render) it doesn't paginate at all. It would appear that the PDF emitter attempts to keep the innermost detail row together regardless of size or pagination settings. I would recommend you follow that up by reporting a bug. When you do so, please remove the top two lines from your table header as they are irrelevant to the report issue.
Re: How to control pagebreak on PDF report [message #534352 is a reply to message #534295] Tue, 18 May 2010 19:21 Go to previous messageGo to next message
By the way, I can think of a couple of ways to work around this issue if you actually have multiple rows in the detail section, but I really think your intent was to show only the inner row related to the outer record.
Re: How to control pagebreak on PDF report [message #534355 is a reply to message #534352] Tue, 18 May 2010 19:44 Go to previous messageGo to next message
Richard,
I didn't linked the outer table and inner table together in the simple report because I need create the case that inner table has more records back using the birt simple DB .
Only in that case, with unchecked "repeat header", the problem happened.
In my production report, I did linked the outer table and inner table. 80% reports work fine. Only some reports , when the inner table has more records (up to 100 records back), I see the problem.
If you think it is a bug, how I can report the bug? Where?
Thanks!
Amy
Re: How to control pagebreak on PDF report [message #534358 is a reply to message #534295] Tue, 18 May 2010 20:11 Go to previous messageGo to next message
Bugzilla is located at:
https://bugs.eclipse.org/bugs/index.cgi
I think you'll need to set up a separate login there, and you want to simpllify your rptdesign file as much as possible, i.e. delete those two header lines. You may want to copy my description of the issue.
Good luck. If you want, I can look into the workaround I was thinking of and see if it actually works.
Re: How to control pagebreak on PDF report [message #534511 is a reply to message #534358] Wed, 19 May 2010 11:55 Go to previous messageGo to next message
Richard,
I will report the bug .
Please help to see if you can find other solution for this. I really appreciate it!
Thank you so much!
Amy
Re: How to control pagebreak on PDF report [message #534524 is a reply to message #534511] Wed, 19 May 2010 12:34 Go to previous message
Richard,
When I try to report the bug, I find this knid of bug is reported before.
Bug 295289 - Unwanted pagebreak when rendering to PDF
Follow the solution, I fixed the pagebreak issue now.
Thank you so much!
Amy
Previous Topic:column repetition
Next Topic:Manipulating Flat File Query
Current Time: Tue Apr 16 18:59:47 GMT 2024
Powered by FUDForum. Page generated in 2.57031 seconds
