Home » Modeling » GMF (Graphical Modeling Framework) » How to indicate the generated project name?
icon5.gif  How to indicate the generated project name? [message #533579] Fri, 14 May 2010 15:43 Go to next message
mestouni is currently offline mestouniFriend
Please I have many .gmfgen files, for different editors, but when I generate the code, all the editors are generated in one project, and none of them work.
please can any one tell me how to indicate the project name in the .gmfgen file
thank you
Re: How to indicate the generated project name? [message #533592 is a reply to message #533579] Fri, 14 May 2010 16:20 Go to previous messageGo to next message
Aurélien Pupier is currently offline Aurélien PupierFriend
Gen editor Generator-> Gen plugin and in properties view ID
Aurélien Pupier - Red Hat
Senior Software Engineer in Fuse Tooling team
Re: How to indicate the generated project name? [message #533598 is a reply to message #533592] Fri, 14 May 2010 16:43 Go to previous messageGo to next message
Thanks, now I have two separated projects,
but I have an other problem, one of the editors does not work.
when I generate only one of them it works, but when I generete them both, one of them doesn't work.
any solution please??
Re: How to indicate the generated project name? [message #535617 is a reply to message #533598] Mon, 24 May 2010 22:09 Go to previous message
SebastianFriend
Are you generating complete RCP applications or plugins? And do you have any error messages from the none-working editor, e.g. from the <workspaceroot>/.metadata/.log file?
Previous Topic:GMF Figure Examples
Next Topic:How to create own loader of model for GMF-based editor
Current Time: Thu May 30 16:32:14 GMT 2024
Powered by FUDForum. Page generated in 0.04123 seconds
