Using a report as a datasource [message #531936] |
Thu, 06 May 2010 14:27 |
Originally posted by: tubahrens.gmail.com
I was under the impression that any report can be used as a data source in
its own right. Does anyone know where the documentation is that shows how
to do this? When I go to create a new data source it is not readily evident
how to select a report as the data source itself.
Byron
Re: Using a report as a datasource [message #532021 is a reply to message #531936] |
Thu, 06 May 2010 18:50 |
Byron,
In the open source designer this is currently not implemented. In the
Actuate product you can use an rptdocument as a datasource.
Jason
> Thanks
> Byron
Re: Using a report as a datasource [message #532023 is a reply to message #532021] |
Thu, 06 May 2010 19:20 |
Okay thanks for the clarification.
"Jason Weathersby" <jasonweathersby@windstream.net> wrote in message
news:hrv321$jdq$4@build.eclipse.org...
> Byron,
> Jason
>> in
>> how
>> evident
>> Thanks
>> Byron
FUDForum. Page generated in 0.04230 seconds
