Home » Archived » BIRT » Set a role in db/use existing db-connection
Re: Set a role in db/use existing db-connection [message #531700 is a reply to message #531675] |
Wed, 05 May 2010 20:00 |
Klaus,
You may be able to use the driverBridge extension point to do this.
Take a look at the three blog post pointed out in this forum post:
http://www.birt-exchange.org/forum/deploying-integrating-bir t-report-engine-applications/19466-reportengine-jdbc-issue-s as-jdbc-drivers.html#post64064
Jason
On 5/5/2010 2:18 PM, Klaus Meisl wrote:
> In my RCP application the user gets a different role which is set on the
> database after logging in the application by sql query "SET ROLE xy".
> I'm using birt viewer to load reports in an integrated swt browser. Now
> I get an error:
> detail : org.eclipse.birt.report.engine.api.EngineException: Cannot
> execute the statement.
> SQL statement does not return a ResultSet object.
> SQL error #1: User 'Klaus@000' does not have execute
> permission on FUNCTION 'RTE'.'CURRENT_DATABASESERVERTIME'.
> So it seems that I don't have permission, though I'd have it in my
> application. I guess birt viewer opens a new connection, so my role is
> lost. In my application I avoid this by using the same connection which
> is only closed on exiting. So, my question is: can I use this connection
> (java.sql.Connection) saved in an Java variable with BIRT in some way,
> or do I need to set the role on report execution? And if I have to, what
> would be the way? Or are there other ways?
> Thanks.
Re: Set a role in db/use existing db-connection [message #531711 is a reply to message #531700] |
Wed, 05 May 2010 20:50 |
Klaus Meisl Messages: 90 Registered: July 2009 |
Member |
Jason,
thanks.
task.getAppContext().put("OdaJDBCDriverPassInConnection",
this.getConnection());
for my pdf creation works wonderful. Is there anything comparable easy
for WebViewer?
Klaus
Am 05.05.10 22:00, schrieb Jason Weathersby:
> Klaus,
> You may be able to use the driverBridge extension point to do this. Take
> Jason
>> I get an error:
>> Thanks.
Re: Set a role in db/use existing db-connection [message #532014 is a reply to message #531711] |
Thu, 06 May 2010 18:42 |
You could always do in script, like in the beforeOpen:
reportContext.getAppContext().put( .... //You will need some way to
locate your connection );
You may also want to look at this wiki entry:
http://wiki.eclipse.org/Adding_an_Object_to_the_Application_ Context_for_the_Viewer_%28BIRT%29
Jason
On 5/5/2010 4:50 PM, Klaus Meisl wrote:
> Jason,
> thanks.
> for WebViewer?
> Klaus
>> Klaus,
>> Jason
>>> Hi,
>>> I get an error:
>>> Thanks.
Re: Set a role in db/use existing db-connection [message #533220 is a reply to message #531711] |
Wed, 12 May 2010 15:13 |
Member |
It seems BIRT closes the connection after running the report. Can I
avoid this?
Am 05.05.10 22:50, schrieb Klaus Meisl:
> Jason,
> thanks.
> for WebViewer?
> Klaus
>> Klaus,
>> Jason
>>> Hi,
>>> I get an error:
>>> Thanks.
Re: Set a role in db/use existing db-connection [message #533229 is a reply to message #533220] |
Wed, 12 May 2010 15:41 |
Yes. Use the app context setting:
OdaJDBCDriverPassInConnectionCloseAfterUse
set it to false.
Jason
> avoid this?
>> Jason,
>> thanks.
>> for WebViewer?
>> Klaus
>>> Klaus,
>>> Jason
>>>> Hi,
>>>> I get an error:
>>>> Thanks.
Re: Set a role in db/use existing db-connection [message #533390 is a reply to message #533229] |
Thu, 13 May 2010 16:01 |
Member |
I tried
task.getAppContext().put("OdaJDBCDriverPassInConnectionCloseAfterUse ",
false);
and
"false");
but I always get
java.sql.SQLNonTransientConnectionException: No current connection.
when I want to create the second report.
Am 12.05.10 17:41, schrieb Jason Weathersby:
> set it to false.
> Jason
>> avoid this?
>>> Jason,
>>> thanks.
>>> for WebViewer?
>>> Klaus
>>>> Klaus,
>>>> Take
>>>> Jason
>>>>> Hi,
>>>>> on the
>>>>> Now
>>>>> I get an error:
>>>>> which
>>>>> connection
>>>>> what
>>>>> Thanks.
Re: Set a role in db/use existing db-connection [message #533401 is a reply to message #533390] |
Thu, 13 May 2010 16:21 |
Klaus,
Either of those should have worked. Can you download the source for the
jdbc plugin and debug it?
Jason
On 5/13/2010 12:01 PM, Klaus Meisl wrote:
> I tried
> false);
> and
> "false");
> but I always get
>> set it to false.
>> Jason
>>> avoid this?
>>>> Jason,
>>>> thanks.
>>>> for WebViewer?
>>>> Klaus
>>>>> Klaus,
>>>>> Take
>>>>> Jason
>>>>>> Hi,
>>>>>> on the
>>>>>> Now
>>>>>> I get an error:
>>>>>> which
>>>>>> connection
>>>>>> what
>>>>>> Thanks.
Re: Set a role in db/use existing db-connection [message #533402 is a reply to message #533401] |
Thu, 13 May 2010 16:40 |
Member |
Thanks Jason, you're the best!
It was my fault, I accidently closed the connection with close() and did
miss it on reviewing my code.
Klaus
Am 13.05.10 18:21, schrieb Jason Weathersby:
> Klaus,
> Jason
>> I tried
>> false);
>> and
>> "false");
>> but I always get
>>> set it to false.
>>> Jason
>>>> avoid this?
>>>>> Jason,
>>>>> thanks.
>>>>> for WebViewer?
>>>>> Klaus
>>>>>> Klaus,
>>>>>> Take
>>>>>> Jason
>>>>>>> Hi,
>>>>>>> on the
>>>>>>> xy".
>>>>>>> Now
>>>>>>> I get an error:
>>>>>>> role is
>>>>>>> which
>>>>>>> connection
>>>>>>> way,
>>>>>>> what
>>>>>>> Thanks.
Re: Set a role in db/use existing db-connection [message #533403 is a reply to message #533402] |
Thu, 13 May 2010 16:55 |
Glad to hear you got it working.
> Klaus
>> Klaus,
>> Jason
>>> I tried
>>> false);
>>> and
>>> "false");
>>> but I always get
>>>> set it to false.
>>>> Jason
>>>>> avoid this?
>>>>>> Jason,
>>>>>> thanks.
>>>>>> for WebViewer?
>>>>>> Klaus
>>>>>>> Klaus,
>>>>>>> Take
>>>>>>> Jason
>>>>>>>> Hi,
>>>>>>>> on the
>>>>>>>> xy".
>>>>>>>> Now
>>>>>>>> I get an error:
>>>>>>>> role is
>>>>>>>> which
>>>>>>>> connection
>>>>>>>> way,
>>>>>>>> what
>>>>>>>> Thanks.
Re: Set a role in db/use existing db-connection [message #533436 is a reply to message #532014] |
Thu, 13 May 2010 21:28 |
Member |
For other interested people: I solved it by using a AppContext Class
described in Jason's post here:
http://www.birt-exchange.org/forum/deploying-integrating-bir t-report-engine-applications/13317-launching-webviewer-code. html#post42380
I just added "hm.put("OdaJDBCDriverPassInConnection",
Application.getConnection());", that was it.
Am 06.05.10 20:42, schrieb Jason Weathersby:
> Jason
>> Jason,
>> thanks.
>> for WebViewer?
>> Klaus
>>> Klaus,
>>> Jason
>>>> Hi,
>>>> the
>>>> I get an error:
>>>> connection
>>>> what
>>>> Thanks.
Current Time: Thu Apr 25 16:38:29 GMT 2024
Powered by FUDForum. Page generated in 0.03523 seconds
