Home » Modeling » GMF (Graphical Modeling Framework) » Getting the label at the center
Getting the label at the center [message #4765] Thu, 03 August 2006 08:54 Go to next message
Originally posted by: sayed.shoed.tavant.com
I have a node which has a name property.I want to set the label for the
name at the vertical center of my node.I tried to use Constrained
toolbar layout but could not get the desired result.Could anyone please
tell me how to do it.
Sayed Aamir Shoeb
Re: Getting the label at the center [message #5034 is a reply to message #4765] Thu, 03 August 2006 10:01 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Hello!
It's not that hard to write your own draw2d layout; StackLayout may be
a good starting point.
sayed wrote:
> Thanks
> Sayed Aamir Shoeb
Re: Getting the label at the center [message #6434 is a reply to message #5034] Fri, 04 August 2006 04:55 Go to previous messageGo to next message
I think the geoshapes plugin example has this. For example, when you
create a cylinder figure you are prompted to enter some name and that
name appears in the center of the figure.
I started from CylinderEditPart(GeoShapeEditPart, ShapeNodeEditPart) and
digged through the subclasses to see the layout being used but couldnt
get hold of it. My guess is I do not have to write layouts from
scratch!!! Can someone point me to the classes where this is being done
in geoshapes?
Dmitry Stadnik wrote:
> Hello!
> be a good starting point.
> sayed wrote:
>> the name at the vertical center of my node.I tried to use Constrained
>> please tell me how to do it.
>> Thanks
>> Sayed Aamir Shoeb
Re: Getting the label at the center [message #6453 is a reply to message #6434] Fri, 04 August 2006 05:03 Go to previous messageGo to next message
Hello!
Wow - it uses GeoShapeCylinderFigure that extends GeoShapeFigure that
uses modified StackLayout to center content pane )))
You could ask GMF runtime team to refactor this layout manager for
public use or just copy the code.
sayed wrote:
> in geoshapes?
>> Hello!
>> may be a good starting point.
>> sayed wrote:
>>> Hi,
>>> Thanks
>>> Sayed Aamir Shoeb
Re: Getting the label at the center [message #6471 is a reply to message #6453] Fri, 04 August 2006 05:31 Go to previous messageGo to next message
Hei,
Even we got the code, the following code will make the label come in the
center. I will try to make a layout of it
setLayoutManager(new StackLayout() {
public void layout(IFigure figure) {
Rectangle r = figure.getClientArea();
List children = figure.getChildren();
IFigure child;
Dimension d;
for (int i = 0; i < children.size(); i++) {
child = (IFigure)children.get(i);
d = child.getPreferredSize(r.width, r.height);
d.width = Math.min(d.width, r.width);
d.height = Math.min(d.height, r.height);
Rectangle childRect = new Rectangle(
r.x + (r.width - d.width)/2,
r.y + (r.height - d.height)/2,
d.width,
d.height);
child.setBounds(childRect);
Sayed Aamir Shoeb
> Hello!
> that uses modified StackLayout to center content pane )))
> sayed wrote:
>> and digged through the subclasses to see the layout being used but
>> couldnt get hold of it. My guess is I do not have to write layouts
>> from scratch!!! Can someone point me to the classes where this is
>> being done in geoshapes?
>>> Hello!
>>> sayed wrote:
>>>> Hi,
>>>> Constrained toolbar layout but could not get the desired
>>>> result.Could anyone please tell me how to do it.
>>>> Thanks
>>>> Sayed Aamir Shoeb
Re: Getting the label at the center [message #108992 is a reply to message #6471] Mon, 05 March 2007 15:08 Go to previous message
Hi there,
I tried this to get the label of my elliptical node centred. But it
doesn't work. I put it in the CreateNodeFigure-method of *EditPart of
the Figure.
Is it the problem because of the rectangle as box for the ellipse? I
also iterated a step deeper with the children, so I can get the label of
the ellipse, but here too -> nothing happens with the label, I is top
centred but not vertically.
Thanks for help
Jens
sayed schrieb:
> Hei,
> IFigure child;
> Dimension d;
> d.width,
> d.height);
> Sayed Aamir Shoeb
>> Hello!
>> sayed wrote:
>>> Hi,
>>>> Hello!
>>>> sayed wrote:
>>>>> Hi,
>>>>> Thanks
>>>>> Sayed Aamir Shoeb
Previous Topic:How to modify key bindings
Next Topic:GMF Tutorial Part 3 - Custom Actions
Current Time: Sat Jul 19 14:09:07 EDT 2025
Powered by FUDForum. Page generated in 0.03539 seconds
