Re: How to set null value to Cascading Parameter [message #530440 is a reply to message #530417] |
Thu, 29 April 2010 15:39 |
Does this report work in the WebViewer?
On 4/29/2010 11:26 AM, sen K wrote:
> Can I get some help, in setting null value to one of my cascading
> parameter.
> Let me put my question clear -
> I have three cascading parameters which using multi dataset to populate
> drop down list.The first two cascade parameters are inter dependent and
> I can do submit without entering / selecting any value for the third one.
> I already set as not required parameter to this and need not to set with
> Default / NULL value for this parameter.
> With these setup, when I submit to generate the report - I am getting
> error msg -which expecting some value for this parameter.
> someone could help me out to achieve this.
> I appreciated.
> Thanks
> Sen K
Re: How to set null value to Cascading Parameter [message #530736 is a reply to message #530542] |
Fri, 30 April 2010 16:20 |
What exact error are you getting. I just tried this in the viewer and
it worked fine. The only way I know to remove the null is to change the
js parameter dialog to strip it out. This would affect all cascades
though. Look at ComboBoxParameterFragment.jsp in the viewer.
Jason
On 4/30/2010 2:18 AM, sen K wrote:
> Jason,
> we already checked with web viewer too, but forgot to mention in my
> earlier post.As per the requirement , we need to submit wihtout
> selecting anyother values for my third parameter. :roll:
> Guide me out to achieve this one.
> Thanks
> Sen
FUDForum. Page generated in 0.03390 seconds
