Sort X-axis when optionally grouped by Y-axis [message #529567] |
Mon, 26 April 2010 12:36 |
Fane Prapad Messages: 7 Registered: April 2010 |
Junior Member |
I have a chart (Scatter Chart) that displays some error rates series with 4 columns: Error name(X-axis), and Error rate,in percentage values(Y-axis), Error interval and Sort order(sort order of the Error names).
I need to display these Error rates according to how they fit in the following intervals:
- <20% (colored in green)
- >=20% and <=50% (yellow)
- >50% (red)
I managed to display them in the chart(using scripting to color the markers) by "optionally grouping" them on a 3rd column, Error interval, that I have calculated within the same query on the database.
My problem is that when I "optionally group Y series" on the 3rd column, the Sorting on X-axis is not applied anymore on "sort order" column, but on Error name alphabetically. When I am using this grouping option on Y series, the sorting tab for X-axis values is disabled.
Is there any way of sorting the X-axis values using a different field - other than those used for X and Y-axis values - when the "optional Y series grouping" is used?
Edit/Delete Message
FUDForum. Page generated in 0.02619 seconds
