EMF Compare [message #528525] |
Tue, 20 April 2010 19:50 |
Fatih Ok Messages: 8 Registered: April 2010 |
Junior Member |
Hello Everybody,
i want to compare two UML-XMI files. Running the following code results in the error:
Loading resources.
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package with uri 'http://www.omg.org/XMI' not found. (file:/C:/Users/sekemitekken/workspace3/xmidiff/KuchenrezeptAltova_unv.xmi, 3, 101)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLLoadImpl.java:83)
public void startDiff() {
Resource.Factory.Registry.INSTANCE.getContentTypeToFactoryMap().put(
XMI2UMLResource.UML_METAMODEL_2_1_NS_URI,
XMI212UMLResource.Factory.INSTANCE);
// Creates the resourceSets where we'll load the models
final ResourceSet resourceSet1 = new ResourceSetImpl();
final ResourceSet resourceSet2 = new ResourceSetImpl();
try {
System.out.println("Loading resources.\n"); //$NON-NLS-1$
// Loads the two models passed as arguments
final EObject model1 = ModelUtils.load(new File("C:\\Users\\sekemitekken\\workspace3\\xmidiff\\KuchenrezeptAltova_unv.xmi"), resourceSet1);
final EObject model2 = ModelUtils.load(new File("C:\\Users\\sekemitekken\\workspace3\\xmidiff\\KuchenrezeptGrGen_orig.xmi"), resourceSet2);
// Creates the match then the diff model for those two models
System.out.println("Matching models.\n"); //$NON-NLS-1$
final MatchModel match = MatchService.doMatch(model1, model2, Collections
.<String, Object> emptyMap());
System.out.println("Differencing models.\n"); //$NON-NLS-1$
final DiffModel diff = DiffService.doDiff(match, false);
System.out.println("Merging difference to args[1].\n"); //$NON-NLS-1$
final List<DiffElement> differences = new ArrayList<DiffElement>(diff.getOwnedElements());
// This will merge all references to the right model (second argument).
MergeService.merge(differences, true);
// Prints the results
try {
System.out.println("MatchModel :\n"); //$NON-NLS-1$
System.out.println(ModelUtils.serialize(match));
System.out.println("DiffModel :\n"); //$NON-NLS-1$
System.out.println(ModelUtils.serialize(diff));
} catch (final IOException e) {
e.printStackTrace();
// Serializes the result as "result.emfdiff" in the directory this class has been called from.
System.out.println("saving emfdiff as \"result.emfdiff\""); //$NON-NLS-1$
final ComparisonResourceSnapshot snapshot = DiffFactory.eINSTANCE
.createComparisonResourceSnapshot();
snapshot.setDate(Calendar.getInstance().getTime());
snapshot.setMatch(match);
snapshot.setDiff(diff);
ModelUtils.save(snapshot, "result.emfdiff"); //$NON-NLS-1$
// shouldn't be thrown
} catch (final InterruptedException e) {
The XMI file that is parsed begins like this and is a valid XML format:
<xmi:XMI xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:uml="http://schema.omg.org/spec/UML/2.1" xmi:version="2.1">
<xmi:Documentation contact="www.altova.com" exporter="Altova UModel2008sp1" exporterVersion="2.2"/>
<uml:Package xmi:id="U00000001-7510-11d9-86f2-000476a22f44" name="Root" visibility="public">
<packagedElement xmi:type="uml:Package" xmi:id="U00000003-7510-11d9-86f2-000476a22f44" name="Component View" visibility="public"/>
I do not understand why. I would really appreciate any help.
[Updated on: Tue, 20 April 2010 19:51] Report message to a moderator
Re: EMF Compare [message #528600 is a reply to message #528525] |
Wed, 21 April 2010 08:47 |
--------------010402050203040005070607
Content-Type: text/plain; charset=UTF-8; format=flowed
I've answered this on your bugzilla :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=308926 .
As mentionned in my answer, you need both the registration of a factory
with
Resource.Factory.Registry.INSTANCE.getContentTypeToFactoryMa p().put(XMI2UMLResource.UML_2_1_1_CONTENT_TYPE_IDENTIFIER,
_and_ a fix in EMF Compare that will not appear before M7 (it has been
commited on HEAD, you could check out the source code of EMF Compare to
benefit from it).
I've added the UML2 newsgroup to the CC list of this answer, there might
be a way to have an "xmi" resource to be loaded within an
"XMI212UMLResource" implementation without using the content-type (The
needed fix for EMF Compare is to take the "contentTypeToFactoryMap" into
account); but I wouldn't bet on it. Maybe you could use
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xmi",
To force loading of any "xmi" file as an OMG UML file ... but this
really seems overkill to me.
Laurent Goubet
Obeo
fatih.ok@gmx.de wrote:
> Hello Everybody,
> in the error:
> Loading resources.
> (file:/C:/Users/sekemitekken/workspace3/xmidiff/Kuchenrezept Altova_unv.xmi,
> 3, 101)
> at
> org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLL oadImpl.java:83)
> try {
> File(" C:\\Users\\sekemitekken\\workspace3\\xmidiff\\KuchenrezeptAl tova_unv.xmi "),
> resourceSet1);
> File(" C:\\Users\\sekemitekken\\workspace3\\xmidiff\\KuchenrezeptGr Gen_orig.xmi "),
> resourceSet2);
> models
> model2, Collections
> //$NON-NLS-1$
> (second argument).
> try {
Content-Type: text/x-vcard; charset=utf-8;
name="laurent_goubet.vcf"
Content-Disposition: attachment;
filename="laurent_goubet.vcf"
YmVnaW46dmNhcmQNCmZuOkxhdXJlbnQgR291YmV0DQpuOkdvdWJldDtMYXVy ZW50DQpvcmc6
PGEgaHJlZj0iaHR0cDovL3d3dy5vYmVvLmZyIj5PYmVvPC9hPg0KZW1haWw7 aW50ZXJuZXQ6
bGF1cmVudC5nb3ViZXRAb2Jlby5mcg0KdXJsOmh0dHA6Ly93d3cub2Jlby5m cg0KdmVyc2lv
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------010402050203040005070607--
FUDForum. Page generated in 0.03052 seconds
