BIRT- Oracle Schema Referenced Not Shown [message #527627] |
Thu, 15 April 2010 19:47 |
Originally posted by: tubahrens.gmail.com
I have successfully added and connected to an Oracle database but the tables
and views i have are not available to the report. When i right mouse click
on the dataset builder i can only see my individual schema which has no
tables. My user has access to read other tables and I can access them
through Oracle in eaither TOAD, SQL Plus or Eclipse DB Perspective and query
so long as I preface the table with the schema smae. This is not working in
the query through the data set definition though.
Any suggestions would be most welcome.
Re: BIRT- Oracle Schema Referenced Not Shown [message #527830 is a reply to message #527627] |
Fri, 16 April 2010 15:03 |
Byron,
Take a look at this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=91425
I doubt this is your issue, but can you open a bug specifying which
oracle driver you are using and what version of BIRT you are using?
Jason
Re: BIRT- Oracle Schema Referenced Not Shown [message #528712 is a reply to message #527830] |
Wed, 21 April 2010 14:42 |
Thanks. it is similar but I do not see any drop down list. my user has no
schemas directly but has access rights to other schemas. in oracle's
plug-in I can see the data schema's without filters but in BIRT I cannot see
a way to turn the user filter off.
"Jason Weathersby" <jasonweathersby@windstream.net> wrote in message
news:hq9u1m$l14$1@build.eclipse.org...
> Byron,
> I doubt this is your issue, but can you open a bug specifying which oracle
> Jason
>> tables and views i have are not available to the report. When i right
>> mouse click on the dataset builder i can only see my individual schema
>> which has no tables. My user has access to read other tables and I can
>> access them through Oracle in eaither TOAD, SQL Plus or Eclipse DB
>> Perspective and query so long as I preface the table with the schema
>> smae. This is not working in the query through the data set definition
>> though.
Re: BIRT- Oracle Schema Referenced Not Shown [message #528785 is a reply to message #528712] |
Wed, 21 April 2010 18:03 |
Byron,
Did you open a bug specifying the driver?
Also can you try the JDBC Database connection for Query
Builder[Prototype] datasource?
Jason
>> Byron,
>> Jason
>>> though.
Re: BIRT- Oracle Schema Referenced Not Shown [message #528786 is a reply to message #528785] |
Wed, 21 April 2010 18:20 |
I wanted to make sure I could reproduce the issue prior to writing a bug. I
have been using both JDBC drivers with the same effect but I will try again
with steps to reproduce.
news:hqnef1$b9e$3@build.eclipse.org...
> Byron,
> Also can you try the JDBC Database connection for Query Builder[Prototype]
> datasource?
> Jason
>> no schemas directly but has access rights to other schemas. in oracle's
>> see a way to turn the user filter off.
>>> Byron,
>>> Jason
>>>> though.
Re: BIRT- Oracle Schema Referenced Not Shown [message #528943 is a reply to message #528786] |
Thu, 22 April 2010 13:13 |
It turns out it is the oracle jdbc driver that causes the issue. The
default 10G driver seems to not default to filtering by user schema.
"Byron Ahrens" <tubahrens@gmail.com> wrote in message
news:hqnfl4$k9s$1@build.eclipse.org...
>I have been using both JDBC drivers with the same effect but I will try
>again with steps to reproduce.
>> Byron,
>> Jason
>>>> Byron,
>>>> Jason
>>>>> can access them through Oracle in eaither TOAD, SQL Plus or Eclipse DB
>>>>> definition though.
FUDForum. Page generated in 0.02550 seconds
