Re: Crash Eclipse on creating new chart [message #521446 is a reply to message #521428] |
Wed, 17 March 2010 15:46 |
Stefano,
Are you using the allinone download?
Jason
Stefano wrote:
> Process: eclipse [903]
> Path: /Applications/eclipse/Eclipse.app/Contents/MacOS/eclipse
> Identifier: org.eclipse.eclipse
> Version: 3.5 (3.5)
> Code Type: X86 (Native)
> Parent Process: launchd [147]
> Date/Time: 2010-03-17 15:30:52.233 +0100
> OS Version: Mac OS X 10.6.2 (10C540)
> Report Version: 6
> Interval Since Last Report: 8726 sec
> Crashes Since Last Report: 2
> Per-App Interval Since Last Report: 8553 sec
> Per-App Crashes Since Last Report: 2
> Anonymous UUID: 873EA19F-CBD7-4394-8105-C3F4C035EF12
> Exception Type: EXC_BAD_ACCESS (SIGBUS)
> Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000000001f0
> Crashed Thread: 0 Dispatch queue: com.apple.main-thread
> Application Specific Information:
> Java information:
> Exception type: Bus Error (0xa) at pc=0x977360de
> Java VM: Java HotSpot(TM) Client VM (14.3-b01-101 mixed mode macosx-x86)
> When I click finish on a wizard to add a new chart on a report, Eclipse
> crash and closed without saving project. How can I resolve this problem
> ? It happens every time i try to insert a new chart.
Re: Crash Eclipse on creating new chart [message #521460 is a reply to message #521447] |
Wed, 17 March 2010 11:30 |
Stefano,
Can you try a clean install with only the Galileo BIRT SR1 or SR2
install and do not add any other plugins? It will make it easier to
isolate the issue.
Jason
Stefano wrote:
> If you refer to Eclipse version yes, i download the Eclipse Galileo
> BIRT..then I add some other plugin.
> I note that the crash happen only when i insert as data of chart a
> reference to a Data Set.
FUDForum. Page generated in 0.04785 seconds
